track slip, Halltech yellow jacket, tune, Borla mufflers - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 9 Old 04-15-2010, 08:11 AM Thread Starter
jnm2003's Avatar
Stock tires 27 lbs of pressure, halltech Intake, tune, hurst short throw, borla axle back mufflers. ran a 12.64 @ 111.52. I ran 112 mph on two passes but a slower time and 60ft.
2010 1SS IBM M6
ordered Oct 19
delivered Dec 4
jnm2003 is offline
post #2 of 9 Old 04-15-2010, 08:17 AM
RedJewel2SS's Avatar
that's pretty **** good!
throw on some headers and retune, shave another .3-.5 seconds off
Gone but not Forgotten!
RedJewel2SS is offline
post #3 of 9 Old 04-15-2010, 08:23 AM Thread Starter
jnm2003's Avatar
Instead of PDF i uploaded a pic.
2010 1SS IBM M6
ordered Oct 19
delivered Dec 4
jnm2003 is offline
post #4 of 9 Old 04-15-2010, 08:28 AM Thread Starter
jnm2003's Avatar
Thanks man! I appreciate it.. its nothing to crazy of a time but im happy with it!! I think i can still get a hair faster time! I was havin problems with my shifter smoothly goin into second gear so i was almost granny shifting 2nd. I got it fixed and hopefully my shead a little.
I ran 12.82 @ 110 stock. Ran two 112 passes but bad 2.0 60fts so know i got the MPH to run a little more!
2010 1SS IBM M6
ordered Oct 19
delivered Dec 4
jnm2003 is offline
post #5 of 9 Old 04-15-2010, 08:44 AM
a set of drag radials on some Z06 wheels will solve your problems
post #6 of 9 Old 04-15-2010, 11:28 AM
OctaneZ28's Avatar
Nice times!
Wow, that's a nice 60-foot time on the stock tires, it's getting out of the hole nicely.
OctaneZ28 is offline
post #7 of 9 Old 04-20-2010, 01:15 PM Thread Starter
jnm2003's Avatar
Originally Posted by OctaneSS/RS View Post
Nice times!
Except when the clutch pedal sticks!! that pass it stuck about and inch from the top but the spring popped it all the way out so i got lucky i didnt have to push the clutch in and ruin the pass!!
I plan on going to the dealer i hear they have a upgraded pressure plate for the clutch. If thats not the problem im going to get them to find out what! Im tired of my best 60fts being ruined bc of the clutch.
Thanks to all the replies!!
which z06 rims fit?.. smallest is 18s? The c6 rims dont.. even 20s?? and what color like chrome or silver, etc are the lightest and normally go for the cheapest? i dont want to spend money on an expensive drag only rim! thanks again!!
2010 1SS IBM M6
ordered Oct 19
delivered Dec 4
jnm2003 is offline
post #8 of 9 Old 04-20-2010, 01:39 PM
i saw a car with the C5 Z06 wheels just on the rear with nitto drag radials. his were black but i would assume they are all the same weight. the natural finished ones or black painted ones are the cheapest.
post #9 of 9 Old 04-22-2010, 09:23 AM
Rodimus Prime's Avatar
Bro, that problem has been a thorn in GM's side since 1998 and was a major contributing factor to me getting the a6. No GM clutch is going to fix that problem. You need a good aftermarket clutch and then pray that fixes it.
The problem is the clutch fluid boils in the line causing a starvation of the slave cylinder which is why the pedal doesnt come back up.
On my 1998 Camaro this problem started for me when I installed long tube headers.
Then I did the drill mod (not necessary anymore) changed the slave cylinder, changed the master cylinder, changed the line connecting them. Heat wrapped the headers, put the clutch line in a heat sleave, upgraded to a z06 clutch. The only time the problem went away was when I switched to a th350 trans.
No reason was specified.
Rodimus Prime is offline
