Work in progress: LED in the dome light console - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 13 Old 02-01-2011, 03:52 PM Thread Starter
FranknBeans's Avatar
Post Work in progress: LED in the dome light console
My wife's HHR has a single LED in the roof liner. I like this idea. . . So, I am attempting a DYI.
I got picked up a OEM LED from the doors.
I modified a regular plastic ground effects clip. Added two pieces of double sided tape on each end.
I was trying to make the clip the same level as the LED holder.
Temp install.
The LED will be shining through one of the stock holes in the console. There's no microphone on the passenger side.
On Star / Hands free Microphone.
Diver side where the mic goes.
Installed.
What I wanted to do is purchase another microphone and use it to hold the LED.. . . why I am NOT doing that is because that little mic is $70!!!
Still not sure if I like the way the LED is installed. . . I am open for any thoughts.
FranknBeans is offline
post #2 of 13 Old 02-01-2011, 04:36 PM
TonyNo's Avatar
Good idea!
Maybe you can ditch the GM LED housing and use a snap-in holder?
Can you get a full shot of the front so we can get a better look?
Also, is there a good way to get that panel out?
TonyNo is offline
post #3 of 13 Old 02-01-2011, 05:18 PM Thread Starter
issue with the snap in holder. . . You don't want to actually see the LED. . . It will be to bright and shining right in your eye at night. . Thus the "tunnel" from the OEM LED holder. .
post #4 of 13 Old 02-01-2011, 05:25 PM Thread Starter
i also didn't want to drill any new holes. . the idea is to have it look stock still.
post #5 of 13 Old 02-02-2011, 07:48 PM
Thanks for the info and pictures....I will think about this. BTW, I love our HHR also, good pair"HHR+Camaro"!
post #6 of 13 Old 02-02-2011, 08:17 PM
54inches's Avatar
Any functioning pics?
54inches is offline
post #7 of 13 Old 02-02-2011, 10:03 PM Thread Starter
Nope. . . I have a friend that is going to manufacturer a piece of aluminum that is the size of the mic so it can snap in the holder. . .
post #8 of 13 Old 03-17-2011, 01:54 AM
Bay Area SS's Avatar
Bro sweet idea, I would love to do that to mine, but I was lost after the first pic. Im sure its gunna look slick! LOL
Bay Area SS is offline
post #9 of 13 Old 04-14-2011, 09:21 AM Thread Starter
Update:
To take the unit out, you need to push the clips in.
Then the two screws found at the black "L" brackets.
I cut back the plastic on the LED.
Made a holder out of a chunk of plexi glass.
I painted it black.
Then I hot glued it in place.
post #10 of 13 Old 04-14-2011, 09:34 AM
TonyNo's Avatar
So, the clips and screws are to get the light housing out of the overhead console?
TonyNo is offline
