L.E.D. Dash Lights/194's - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 9 Old 02-19-2011, 01:17 PM Thread Starter
Does anyone know what type of bulbs (if any) the dash lights use. I found a cool web site and was wondering if we could use some of these LED in our dash lights. Are they still using the plug in lights from 19 forgotten. I have not gotten under my dash since been sick.
I did a thread search and did not see anything.
http://www.superbrightleds.com/led_prods.htm
post #2 of 9 Old 02-19-2011, 05:13 PM
skuttduck's Avatar
Far as I can tell is that everything is LED from the 4 pack gauges to the instrument panel, including the door lights, and sunroof button.
The only lights not LED are the daytime running lights, the headlights (halogen or HID), domelight, and the trunk light.
skuttduck is offline
post #3 of 9 Old 02-19-2011, 07:00 PM Thread Starter
Yea, could i change the colors..
post #4 of 9 Old 02-19-2011, 07:52 PM
skuttduck's Avatar
Of the LED's?
It would be possible if you are real good with a soldering iron.
post #5 of 9 Old 02-20-2011, 06:50 AM Thread Starter
If GM used the standard/194 bayonett bulb sockets then it would just be plug in the new colored LED bulbs. I will look under the dash today and see what I can see..
post #6 of 9 Old 02-20-2011, 09:21 AM
TonyNo's Avatar
I think I have seen that the cluster uses board-mounted chip LED's.
TonyNo is offline
post #7 of 9 Old 02-20-2011, 12:06 PM
skuttduck's Avatar
Correct. I saw someone who took their gauge cluster apart on the other site.
post #8 of 9 Old 02-20-2011, 01:43 PM Thread Starter
Thanks, Since the dome light is a plug type can we just change the color as we want?? The site I fould has a lot of cool colors LED for cheap.
post #9 of 9 Old 02-20-2011, 02:37 PM Thread Starter
I just pulled my dome light ans it a 12v w5 plug in type of bulb. I think I should be able to change it out with what ever color I want.
