AAC Footwell Lighting! - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 16 Old 03-01-2011, 07:22 AM Thread Starter
IOMCowboy's Avatar
Ok so I already installed my footwell lighting and wired it to my dome light so that it comes on when the doors are unlocked or open.
I also wanted the option to turn them on when the dome light was off.
I pondered this for a day or two and finally came up with this.
In the first picture you can see I wired to the dome light.
I decided to wire a switch to the lights....but how to make them work with both the dome light and the switch. Well I installed a switch in the center counsel.
I then tapped the positive wires from the Footwell lighting and took them to the input on the switch. I also tapped the ground from the lighting and took that wire to the switch as well.
I then took a positive lead from the fuse box to the input on the switch.
The result is a success. The lights come on with the door open, unlock button pushed and with the dome light switch. With a simple flick of the switch I installed the lights stay on until I turn them off.
Texas Speed 1 7/8 LT Headers, Texas Speed High Flow Cats, Magnaflow 3 inch Cat Back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor
My car is exactly that; No one has to like it but me!
IOMCowboy is offline
post #2 of 16 Old 03-01-2011, 09:05 AM
Good Job.....
post #3 of 16 Old 03-01-2011, 09:54 AM Thread Starter
IOMCowboy's Avatar
Thanks.
post #4 of 16 Old 03-01-2011, 10:08 AM
Good job, looks good and thanks for the tip!
post #5 of 16 Old 03-01-2011, 12:30 PM Thread Starter
IOMCowboy's Avatar
Your welcome!
post #6 of 16 Old 03-09-2011, 08:55 PM Thread Starter
IOMCowboy's Avatar
post #7 of 16 Old 03-09-2011, 11:23 PM
Eagle Soars's Avatar
Really good idea and setup . Something I actually want to do with mine. Couple questions:
It looks like you have the orange interior trim (can't see seats but I assume they are too).
Are they the Amber color? Does it look good and orange?
Which type of strip did you go with as I think they had 2 types, and how long (12" or 15")? Why did you choose that type?
Where are your lights under the hood and what type are those?
Ok, it was more than a COUPLE questions.
Thanks!
Eagle Soars is offline
post #8 of 16 Old 03-10-2011, 06:42 AM Thread Starter
IOMCowboy's Avatar
The interior lights are the Amber footwell lighting from AAC (flexable strips) I think they are the 12". I also have their amber LED inerior and trunk light bulbs. Yeas I do have the IOM Interior.
Under the hood are just lights I baught from Autozone. The one over the radiator is a
18" stip and the the ones in the engine cover are 6" strips.
post #9 of 16 Old 03-10-2011, 12:48 PM
Cool!
In your opinion, does the Amber LED Dome light give you sufficient light to read something at night (i.e. a map, the owners manual, a speeding ticket , etc.).
I like the look but am concerned about function as well (for the dome light).
So the footwell strips are the type (non-CCFL) that did NOT have an inverter inline in the wiring? If so they must be their LED strip.
Is your switch a SPST or DPDT switch. It looks like SPST.
Thanks!
post #10 of 16 Old 03-10-2011, 01:30 PM Thread Starter
IOMCowboy's Avatar
I think it does but i have 20 / 15 vision also. No there is no inline inverter in the wiring. It is just a SPST I baught from autozone for 3 bucks I think.
