Quirky Window Switches - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 17 Old 04-28-2011, 08:12 PM Thread Starter
Spok's Avatar
More often that not, when I press both window switches completely down or lift them completely up to activate their automatic travel to the completely down or up position, one or both of the windows stop their travel as soon as I release the switch. I have to press the switch(es) again to get the window to travel the rest of the way.
Does anyone else have this problem? Any solutions other than taking it to the dealer?
Spok is offline
post #2 of 17 Old 04-29-2011, 06:59 AM
kc0cmj's Avatar
Resync the travel. Do one at a time. Hold down the switch, after the window is all the way down, keep holding it in down position for 5 seconds. Release and pull switch to up position, once up all the way hold for 5 seconds. Do this procedure 2 times. Then do it to other window. Should fix your problem. You will most likely have to do this anytime a battery goes weak or dead too.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #3 of 17 Old 04-29-2011, 07:37 PM Thread Starter
Spok's Avatar
kc0cmj:
Thanks! I'll give it a try and let you know what happens.
Seems as though not even windows on these new-fangled cars can remember what they're supposed to do. Maybe we'd be better off if the worst thing that could happen is the crank comes off in your hand.
Spok is offline
post #4 of 17 Old 04-30-2011, 09:49 PM Thread Starter
Spok's Avatar
It seems as though this procedure hasn't changed anything. I still get times when the window(s) either stop on the way down when I release the switch or on the way up.
The procedure in the manual (similar to that recommended above) is meant to reprogram the Express Up feature. Since I'm also having a problem with Express Down, reprogramming might not be the answer.
Spok is offline
post #5 of 17 Old 05-03-2011, 01:13 PM Thread Starter
Spok's Avatar
Is anyone else having the same type of problem with the Express Up/Down features on the windows? If so, have you found a solution or is this something I need to address with the dealership?
Spok is offline
post #6 of 17 Old 05-03-2011, 01:33 PM
I have the same problem...but thought when I ever got motivated enough to read the manual...I could solve it myself. Maybe I'd better try to solve it now. So crap...now I have a problem I didn't even know I had...lol.
post #7 of 17 Old 05-03-2011, 02:40 PM
kc0cmj's Avatar
Might be a software problem, take to dealer, window switches are actually window modules now that require software for them to work. Could just need it reflashed and help the problem, I havent done any, no complaints brought in yet here at my dealership for that.
kc0cmj is offline
post #8 of 17 Old 05-03-2011, 04:17 PM
Are you holding the switch down or up when doing this? If so then when you let go it will stop you have to touch and release for them to do automatic.
post #9 of 17 Old 05-04-2011, 01:30 AM Thread Starter
Spok's Avatar
bamaproshop:
Come to think of it, I may be a bit heavy handed with the switches just like I am with the turn signal lever when I just want it to blink 3 times. Sometimes instead of just tapping it, I'll wind up pushing the lever down. I'll try the light touch as you suggest and let you know how it works.
Envy:
Are you reading this? It might solve your problem that you didn't know you had.
Spok is offline
post #10 of 17 Old 05-04-2011, 07:54 AM
bamaproshop:
Envy:
Cool hope that works
