Bluetooth Audio, what gives? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 26 Old 05-08-2011, 07:55 AM Thread Starter
O.K. The book says that it supports Bluetooth audio streaming, however, my phone does not recognize the car as a media capable pairing. Phone is an original motorola droid, and it streams just fine in the Taurus and with media bluetooth headsets. What gives?
Devryn is offline
post #2 of 26 Old 05-08-2011, 09:53 AM
Hmmmmm my droid works fine with mine? Wonder if previous owner messed it up might want dealership to take a look.
post #3 of 26 Old 05-08-2011, 10:00 AM
425hp69's Avatar
My Hero streams Pandora fine but sirius is choppy, I put a 64Gb flash drive with every song known to man on it and that was that.
425hp69 is offline
post #4 of 26 Old 05-08-2011, 10:39 AM Thread Starter
Is there something special you have to do to pair it? When I add it via phone pair or gps pair, it sees it and pairs it, but it won't pair media streaming. This is really frustrating. I have an hour and a half ride to work each day and I'm really used to blasting pandora or slacker.
Devryn is offline
post #5 of 26 Old 05-09-2011, 07:12 AM
cj7ngolf's Avatar
Not possible, since the camaro limits it to 10,000 songs... Anyway/....
cj7ngolf is offline
post #6 of 26 Old 05-09-2011, 09:43 AM
If nothing... maybe download to a memory stick
Hope this helps
post #7 of 26 Old 05-09-2011, 09:48 AM
kc0cmj's Avatar
I have a samsung Facinate. I stream all the time through the blue tooth, both Pandora and MP3 player.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #8 of 26 Old 05-09-2011, 10:04 AM
kc0cmj's Avatar
BLUETOOTH
PI0055A: Radio Display May be Missing Data When Using USB - Noise, Static, Source Management Difficulties - iPod, Bluetooth, USB or UMS Operation Intermittent/Inoperative at Start Up, During Playback, Call End - (Apr 25, 2011)
Subject:
Radio Display May Be Missing Data When Using Universal Serial Bus (USB) -- Noise, Static, Source Management Difficulties -- iPod®, Bluetooth®, USB or UMS Operation Intermittent or Inoperative at Start Up, During Playback, After Call Has Ended (Replace and/or Reprogram Multimedia Player Interface Module (MPIM))
Models:
2010-2011 Buick LaCrosse
2011 Buick Regal
2010-2011 Cadillac SRX
2010-2011 Chevrolet Camaro, Equinox
2011 Chevrolet Cruze, Malibu
2010-2011 GMC Terrain
2010-2011 Opel Insignia
Equipped With Audio Interface RPO KTA, Audio Interface-Wireless RPO KTB or Accessory Interface Module
Attention:
This electronic control module may be referred to as a multimedia player interface module (MPIM) or a preferred device interface module (PDIM) or a PDIM multimedia player interface module.
This PI is being revised to add the 2011 model year, additional models and to update the Subject, Condition, Recommendation, Warranty and trademark information. Please discard PI0055.
The following diagnosis might be helpful if the vehicle exhibits the symptoms described in this PI.
Condition/Concern
Some customers may comment on any of the following conditions:
Blank lines in the song list display
Incomplete MP3 data that may result in wrong information being displayed
Poor iPod® or universal mass storage (UMS) performance at start up and potential lack of audio during playback
Source management difficulties when using more than one Bluetooth® device
Intermittent device operation from one ignition cycle to the next
Poor static message translations when using French or Spanish as the default language instead of English
Intermittent clicking, static or audio distortion during iPod® or UMS audio playback
At ignition ON, the previous radio source, such as AM, FM or XM®, returns to the USB input rather than the previous radio source selection
The audio source does not revert back to the customer's device after a Bluetooth® call has ended.
These conditions may be caused by a software anomaly.
Recommendation/Instructions
Important: Performing Step 1 will determine if the multimedia player interface module (MPIM) should be reprogrammed or replaced and reprogrammed.
•Press either the: Select or Menu button for approximately 8-10 seconds to display the MPIM hardware and software level.
Note: Cx stands for all C level version hardware.
If the hardware level displayed is: Version Cx, proceed to Step 2.
If the hardware level displayed is: Version DA, proceed to Step 2.
If the hardware level displayed is: Version DB or greater, proceed to Step 3.
•Replace the MPIM. Refer to Multimedia Player Interface Module replacement in SI.
Proceed to Step 3.
Note: On TIS2WEB the revised calibration for this reprogramming may be referred to as PDIM Multimedia Player Interface Module - Programming.
•Reprogram the MPIM using the latest calibration available on TIS2WEB. Refer to the Service Programming System (SPS) procedures in SI.
3.1.
During programming, the battery voltage must be maintained within the proper range of 12-15 volts. Only use the approved Midtronics® PSC 550 Battery Maintainer (SPS Programming Support Tool EL-49642) or equivalent during programming.
3.2.
When using a multiple diagnostic interface (MDI) for reprogramming, ensure that it is updated with the latest software version.
•After successfully reprogramming the MPIM, ensure that any necessary post-programming procedures are performed. Refer to > Programming and Setup > Diagnostic Information and Procedures > Control Module References > Multimedia Player Interface Module Programming and Setup in SI.
kc0cmj is offline
post #9 of 26 Old 05-09-2011, 10:40 AM Thread Starter
Nice. Thanks for that. I'm going to schedule a dealer appt asap.
Devryn is offline
post #10 of 26 Old 05-09-2011, 11:39 AM
kc0cmj's Avatar
Welcome. Hope it helps.
kc0cmj is offline
