PDIM TSB - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 20 Old 06-17-2011, 12:49 PM Thread Starter
PDIM TSB
If anyone is having problems with their IPOD... Zune or anything else plugged into the USB port (noise,,,,not recognizing player,,,ect ) here is the TSB you can bring to dealership to get fixed
post #2 of 20 Old 06-17-2011, 03:01 PM Thread Starter
Took the TSB to the dealership today and they are going to order new PDIM
post #3 of 20 Old 07-15-2011, 05:38 PM
www.camaroscotty.com
Camaro Scotty's Avatar
Helpful post - I have code DA - which states order new MPIM module....
Explains why I SEE the ipod, CONTROL the ipod, but not HEAR the ipod.
Thanks for the post! (and it came up in a google search, even better)
Keywords CAMARO PDIM DOESN'T WORK NO SOUND
http://www.camaroscotty.com
YAHOO IM:
Camaro Scotty is offline
post #4 of 20 Old 07-15-2011, 07:59 PM
weland's Avatar
Thank you Camaro Scotty for bumping this! I've been meaning to get this done for a long time (and consequently get the software up to date). My biggest complaint is:
"Intermittent device operation from one ignition cycle to the next"
I also occasionally get blank lines in the song list display. I noticed in the 2011 user manual that it's stated the PDIM indexes up to 10000 songs instead of the 2500 as with the 2010 version.
Do not taunt Happy Fun Car.
weland is offline
post #5 of 20 Old 07-15-2011, 08:00 PM
weland's Avatar
nevermind
I have a Cx version firmware, so they would need to replace it.
weland is offline
post #6 of 20 Old 07-21-2011, 03:48 PM
OK, we replaced the module, did reprogramming, and STILL NOTHING. It SEE'S the Ipod, CONTROLS the Ipod, but just doesn't PLAY SOUND from the Ipod.
YAHOO IM:
post #7 of 20 Old 07-22-2011, 05:34 PM
weland's Avatar
My local dealer updated the programming on mine and ordered a replacement (it was a Cxx version module). Now it won't play anything on my iPod. If I'm lucky I'll get about 30 seconds of audio before a "no supported device found" error appears. I don't know why they bothered reprogramming, the TSB clearly said a replacement should be ordered instead.
I suspect they may have programmed my older hardware to the latest firmware, which might explain why it isn't working right at all now.
weland is offline
post #8 of 20 Old 07-22-2011, 06:51 PM
We got the replacement... did the same thing....worked with tech support.... tried software AGAIN....now tech support said they should pull one out of a working 2SS on the lot.... W T H ?????
YAHOO IM:
post #9 of 20 Old 07-24-2011, 09:13 AM
weland's Avatar
Well please update this thread if you get a solution that works. It would be nice if there's a logical explanation, like the tech didn't correctly follow the instructions in the TSB. Sometimes when it says, "if (so and so) is true, skip to step 6", it's important to skip to step 6!
weland is offline
post #10 of 20 Old 07-25-2011, 11:26 PM
Wvallediego's Avatar
Wvallediego is offline
