sub enclosure positioning - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 6 Old 06-24-2011, 11:09 AM Thread Starter
my85gs's Avatar
I am about to purchase a sub enclosure from subthump...they offer a box that have front firing subs (subs facing the back seat)..any opinions if this is a better option than the rear firing sub box..Thanks,Rich
my85gs is offline
post #2 of 6 Old 06-24-2011, 11:24 AM
Front firing is definitely the best. I went with two 10" front firing subs and an amp upgrade and I couldn't be happier. The sound especially the bass and the vibe is amazing!
post #3 of 6 Old 06-24-2011, 01:23 PM
Bass will travel every direction. Its up to you. Tweeters and midrange are more dependant on direction.
Toddb is offline
post #4 of 6 Old 06-24-2011, 01:54 PM
My subs were originally mounted on the sides of the trunk and didn't sound as good to me but I'm no expert.
post #5 of 6 Old 06-24-2011, 09:08 PM
Right on. Test and do what sounds best.When it comes to subs experiment.
Toddb is offline
post #6 of 6 Old 08-25-2011, 04:10 PM
It depends how you intend to use the system. If you can fire the subs forward and seal it off so that the pressure doesnt leak back into the trunk it will sound best. However a rear firing enclosure is the easiest and typically sounds better unless you do what I said above. Remember also if the subs are firing directly into the back seat and are very close the seat will actually muffle the sound too. My vote is rear firing.
MBExpeditors is offline
