Issue with Oracle SMD Sidemarkers - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 06-28-2011, 06:48 PM Thread Starter
GHow's Avatar
I just installed the Oracle SMD Camaro Concept Sidemarkers. Let me start off by saying they look AMAZING. Even better than I'd hoped, they're the coolest mod I've done by far.
That being said, I've run into an issue I can't explain. Occasionally (haven't tested enough to give a percentage) when the rest of the lights come on, the front driver side sidemarker does not come on. The other 3 do. In addition, whenever the front driver side sidemarker does not come on, neither do the halo around the driver side headlight, nor either of the foglights (I have the fieldgoal halo harness installed). The headlights and the passenger side halo function correctly. It seems entirely random when it will or will not come on, but if it's on it tends to stay on, and if it's off it stays off through a couple off/on cycles, until eventually seemingly randomly working again. Any ideas on what could be causing this? Is it my halo wiring harness? Or something else? It's worth noting I never noticed this issue with the stock sidemarkers.
Thanks!
2011 Camaro 2SS/RS A6, Cyber Grey
Living the DREAM
GHow is offline
post #2 of 8 Old 06-29-2011, 09:21 AM
54inches's Avatar
Loose wire.
54inches is offline
post #3 of 8 Old 06-29-2011, 10:40 AM
Darkrider's Avatar
Loose wire.
I would have to agree here. With so many lights affected, I would imagine that it is the ground wire that is giving you problems here.
Darkrider is offline
post #4 of 8 Old 07-04-2011, 10:35 PM Thread Starter
GHow's Avatar
Update: So this problem continued and I continued trying to tighten and disconnect and reconnect every conceivable wire. Finally I figured out the issue. I uninstalled fieldgoals daytime running lights harness, and the issue stopped. The sidemarkers work perfectly. The conclusion I've reached is that the modulation built into fieldgoals harness to prevent the PMW signal from burning out the LED's in the aac daytime running light P13W replacements is somehow withholding too much current. My guess (uneducated) would be that the new AAC SMD sidemarkers draw more juice than the OEM sidemarker bulbs, and so this interruption was preventing the sidemarkers, P13W's, and the driver side halo from running, while with the OEM bulbs installed it's not an issue.
Regardless, the sidemarkers and halos all work as they normally should now, but I've had to uninstall my fieldgoal wiring harness. My next step is to reach out to him and see if he has any ideas for a workaround. Just wanted to pass this info along in case anyone ran into similar issues.
Living the DREAM
GHow is offline
post #5 of 8 Old 07-05-2011, 12:00 PM
Buzz's Avatar
Keep us posted. Good find.
Buzz
2010 Synergy Green 1LT
Buzz is offline
post #6 of 8 Old 07-05-2011, 04:58 PM
Great! good info, keep us posted!
post #7 of 8 Old 07-05-2011, 05:42 PM
ModernCamaro.com Sponsor
fieldgoal00's Avatar
Thumbs up
First off, LED's draw less power. Secondly we are not applying a modulated signal with our harness, we actually remove the modulated GM signal by use of the relay. I sent you a PM we'll get you fixed up and happy.
fieldgoal00 is offline
post #8 of 8 Old 07-07-2011, 09:00 PM
Luwinkle's Avatar
What this guy said.
LEDs draw a fraction of the power compared to normal bulbs.
Luwinkle is offline
