Help with Speakers Boston Acoustics - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 10 Old 09-14-2011, 08:42 PM Thread Starter
I am starting research on this now but I was wondering if anyone has had this problem. I got back from work for 2 weeks and started the car up. Everything electronic works fine except the speakers. Turn up the volume on radio cd mp3 whatever and no sound at all from the speakers.
I looked at the fuse for the amplifier and it looks good, but I am going to check it in depth in a few minutes.
Does anyone know where the amplifier is so I can check the plugs running to it? (found where this was on my first search of moderncamaro.com...so thanks to everyone for posting photos and information pertaining to the amplifier)
I really don't want to pull apart the dash to check connections, does anyone have recommendations to troubleshoot this problem? (connections on the amp seemed fine, i hope it's not wires or something behind the dash)
Thanks ahead.
Big Poschmansky is offline
post #2 of 10 Old 09-14-2011, 10:36 PM Thread Starter
Well... I checked the fuses no problems, but found out all the problems are audio related so I think it's the amplifier. Back Up sensors audio, door open with key in ignition and lights on audio, stereo audio, and blinker/hazard lights audio do not make a single sound. Everything else works fine. I guess I will take it to the dealership tomorrow.
post #3 of 10 Old 09-15-2011, 08:10 AM
kc0cmj's Avatar
Prolly the amp, should hopefully be under the warranty still. 3 year 36,000 mile.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #4 of 10 Old 09-15-2011, 08:53 AM
Thier is a amp turn on wire. Check to so if you have pwr thier.I have the amp from my 2011 convertible if you need it. If its the same.
Toddb is offline
post #5 of 10 Old 09-15-2011, 02:05 PM Thread Starter
I am only at 2 years, 26,500 miles so the dealership should take care of it. I am waiting for them to call with news. Thanks for the offer Toddb, but you may want to hang on to it just in case.
post #6 of 10 Old 09-16-2011, 06:55 AM
cool hope you get it fixed soon.
Toddb is offline
post #7 of 10 Old 09-16-2011, 02:49 PM Thread Starter
Well first they thought it was a problem with the radio but they replaced it with a new one and no dice. So they swapped out the amp and it works fine. Should be picking it up here shortly.
post #8 of 10 Old 10-21-2011, 12:33 PM
ユキヒョウ
Nancygrl's Avatar
Just so ya know for future occurances. The BA amp is mounted behind the driver's side trunk liner thingy.
2019 1SS/1LE
Nancygrl is offline
post #9 of 10 Old 04-29-2015, 12:21 PM
My 2010 Camaro with Boston system is having the same problem. Dealership replaced the radio which didn't fix the problem and they are now saying the amp is fine and there is a short somewhere. Should i try replacing the amp anyway?
Symptoms
Day 1 halfway to work the sound starts working
Day 2 3/4 way to work the sound starts working
Day 3 no sound at all turn signals, back up sensors, bluetooth, ect.
Where can i find a cheap amp to just test to see if it fixes the problem first?
Thanks in advance.
griff33 is offline
post #10 of 10 Old 04-29-2015, 01:36 PM
kc0cmj's Avatar
Again prolly the amp, it is located where Nancy said, pull up the trim along the trunk opening, just clipped in, then you can pull the carpet back it is almost behind the driver side tail light just a little lower. The plug is unique to GM so you would have to get a GM amp to test the theory. If you decide to change the amp you can get a harness that plugs in and wire in your own amp instead. SubThump - will have the harness and amps selection.
kc0cmj is offline
