Question on wiring for amp. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 6 Old 12-10-2011, 04:15 PM Thread Starter
ffej0127's Avatar
Quick question for the people who installed their own amps. From where did everyone run their 12v remote wire from?
2SS..IO Interior M6 Black Rally Stripes Borla Mufflers Diablo Tuned 20% Tints Vararam ram air, Eibach front and rear sway bars, BMR trailing arms, BMR toe rods, BMR lower control arms, BMR strut tower brace, SLP Long tubes with high flow cats Granetelli cross drilled and slotted rotors BBK 95mm Throttle body Eibach coil overs, BMR Adjustable Front and Rear Sway Bar End Links Bravado 20" Rims with Eagle F1 305/35/20 in the Rear and 275/35/20 front
ffej0127 is offline
post #2 of 6 Old 12-10-2011, 07:20 PM
kc0cmj's Avatar
I ran mine from the power outlet inside the center console, very easy to get up and then the back seat pops right out, can run wire under the carpet between center console and the back seat area.. it is 12v and only on with the key.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #3 of 6 Old 12-10-2011, 08:33 PM Thread Starter
ffej0127's Avatar
ok good idea. thanks
ffej0127 is offline
post #4 of 6 Old 12-12-2011, 08:47 AM
kc0cmj's Avatar
Also if you are tapping into their existing wiring, go before their amp, not at the speakers or after their amp, you will have loss of power, they have a crossover built into thier amp to reduce the power.. Learned from expeirence.
kc0cmj is offline
post #5 of 6 Old 12-13-2011, 01:35 PM
Ther is a remote turn on wire in the back left side of the trunk. right where the boston amp plugs in. no need to run a wire from the front. I have 3 amps in my car all using the same remote turn on wire. Goes on and off with the radio.Use a tester to find the wire.
Toddb is offline
post #6 of 6 Old 12-21-2011, 07:00 PM
Alfieboy's Avatar
only good IF they have the BA setup-- then ye sthe white wire would be the amp turn on..I believe its the white wire..
Alfieboy is offline
