Turnsignals intio DRLs and Running Lights - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 9 Old 01-04-2012, 06:58 PM Thread Starter
jhiiidoc's Avatar
Is there a way to modify the front turn signals into DRLs?
In other words, on all the time except when blinking....
jhiiidoc is offline
post #2 of 9 Old 02-05-2012, 06:30 PM Thread Starter
jhiiidoc's Avatar
Got tired of waiting
Went searching on another forum and found the instructions.
These are the two plugs you are looking for. One is the headlight plug, the other the turn signal plug.
This is what the turn signal socket looks like from the back. On the RS-equipped cars, the center hole is missing the DRL wire that the non-RS cars have standard. This hole must be drilled out with a 7/32 drill bit to run an 18 gauge wire thru it.
Once the hole has been drilled out, you can pass the wire thru the hole. Draw it thru, then remove about 1/16" insulation. Pull the wire back until it is flush in the plug. Tape the three wires together to maintain the center wire in its correct position.
Take the free end of the wire, and utilizing a t-tap, connect it to the brown wire on the right side headlamp plug (green wire on the left side headlamp plug).
This is the finished product. I ran another set of lines from these lines to the DRLs, and now they are also running.
jhiiidoc is offline
post #3 of 9 Old 02-07-2012, 06:36 AM
Does that also make the turn signal a running light if you have the headlights off?
post #4 of 9 Old 02-11-2012, 09:03 AM Thread Starter
jhiiidoc's Avatar
All the lights would be on except the headlights during the day. Halos, markers, and Turnsignals. I'll post up a photo of what it looks like during the day.
I have now gone one step further and added switchback leds, so now my turnsignals are white and turn yellow for signaling.
jhiiidoc is offline
post #5 of 9 Old 02-11-2012, 09:08 AM Thread Starter
jhiiidoc's Avatar
Here ya go
With Switchbacks installed
jhiiidoc is offline
post #6 of 9 Old 03-11-2012, 10:03 AM
bump
post #7 of 9 Old 03-11-2012, 10:31 AM
My Camaro was not RS equipped so when the performance shop wired my OEM RS headlamps...they wired my HIDS as DRLs and wired the halos to the turn signals so I've always had this set up...but without the fogs on because I have a separate control for that.
I've since taken Envy to two other performance shops (because Quantum went out of business) to have the wiring changed...and both places screwed with my car for a full day and couldn't figure out a thing. Neither place charged me for the work they did because they both said "no problem" we can do that easily. But they did give me quotes of $1000-$1500 to bring the car back and spend as long as it takes their electrical guys to figure it out. But that's ridiculously more than I paid for the install in the first place so I said no thanks. ..Envy will have to stay different.
post #8 of 9 Old 03-16-2012, 02:22 AM
Vann2SS/RS's Avatar
I see how you ran the third wire for the turn siginals. And the extra set for the DRLs, what did you do for the HALOs.
2011 2SS/RS Blk on Blk, M6, CAI intake, MGW shifter, Pfadt lowering springs, & sway bars, Borla "S" Type cat-back, ARH headers, SLP underdrive pulley, 160 termostat, Tune(Matt) Tune Time Performance, Elite Engineer catch can, & tunnel brace, DRL harness (Fieldgoal's) Tinted rear lights, & sidemarkers, Lloyd Mats, AAC LED's drl, dome, license plate, and trunk.
Vann2SS/RS is offline
post #9 of 9 Old 03-16-2012, 05:23 AM Thread Starter
jhiiidoc's Avatar
Halos are on the same circuit as the wire that is t-tapped. So when the DRLs are powered, they come on, and vice-versa, so everything stays on. Headlamps are on a different circuit.
2010 CAMARO 2SS/RS, InTune, BBK Chrome Headers w/ Hi-Flo Cats, DynoMax Cat-Back, Volant CAI, Ported Throttle Body, Eibach Sway Bars, Eibach Springs, SubThump Stealth BA Replacement System, JDP Halos, RGB LED Mailslot Scanner, Carbon Stripe Kit.
jhiiidoc is offline
