Amp turn on with factory radio - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 14 Old 06-19-2012, 07:41 PM Thread Starter
Hi all, i am new to Modern Camaro and new to owning a Camaro have had it two weeks now, i have a JL Audio 12w6 with a ported box and an Alpine radio im going to install in it. It is a 1SS model without BA sound system. I plan on using speaker level inputs and keeping the fctory head unit for now. Any ideas on where to pull the amp turn on from without running wire to the front and searching for a switched wire?
lupejtac is offline
post #2 of 14 Old 06-19-2012, 09:05 PM
jhiiidoc's Avatar
I think you may want to visit subthump.com...they have an adapter that plugs in so you can hook up an extra amp, and I believe it has the wiring included to turn on the amp as well as the speaker to RCA adapters...go check it out...
2010 CAMARO 2SS/RS, InTune, BBK Chrome Headers w/ Hi-Flo Cats, DynoMax Cat-Back, Volant CAI, Ported Throttle Body, Eibach Sway Bars, Eibach Springs, SubThump Stealth BA Replacement System, JDP Halos, RGB LED Mailslot Scanner, Carbon Stripe Kit.
jhiiidoc is offline
post #3 of 14 Old 06-27-2012, 04:14 PM
ユキヒョウ
Nancygrl's Avatar
Yep, check subthump they'll have what you need
2019 1SS/1LE
Nancygrl is offline
post #4 of 14 Old 06-28-2012, 07:12 AM
kc0cmj's Avatar
I tapped into my power outlet inside the center console. It is a key on power outlet. Rear seat pops right out and easy to run wire, took about 10 minutes.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #5 of 14 Old 06-30-2012, 01:35 AM
I did the same thing and works great.
Semydacop is offline
post #6 of 14 Old 07-21-2012, 11:19 AM
ForgedReality's Avatar
Sounds like a half-cooked idea to me. So much easier to just use a remote wire from a breakout harness, the way the amp expects it to work. Plus, it doesn't mess with any of your factory wiring...
ForgedReality is offline
post #7 of 14 Old 07-21-2012, 01:06 PM
rgriffin25's Avatar
I use the Audiocontrol LC2. http://www.audiocontrol.com/t34/1761...l----LC2i.html It is a little pricey, but has worked well for me.
rgriffin25 is offline
post #8 of 14 Old 07-21-2012, 11:17 PM
Why overdo it?
All you need is this Subthump T-Harness. It's plug and play. You hook your factory speaker level inputs from your factory amp to the harness, then the harness to factory amp. There are RCA breakouts and a remote wire that go to the amp that powers your sub. Nothing could be simpler.
post #9 of 14 Old 07-22-2012, 11:10 AM
Do cars with out the BA system have a factory amp. I have an LT1 w/o BA.
post #10 of 14 Old 07-22-2012, 11:20 AM
Every car with a radio has an amp. Otherwise the speakers wouldn't have power.
