JL SUB - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 16 Old 07-16-2012, 03:23 PM Thread Starter
JL SUB
I just bought a 2012 1LT on Saturday and I have a JL sub from my old car. I was wondering where the stock amp is as well as would I be able to wire the sub up to it. I am pretty happy with the sound the way it is but want to add a little more bass. I am getting rid of the old car but don't want to sell it with the sub so I would rather put it in the new car.
Squills is offline
post #2 of 16 Old 07-16-2012, 07:07 PM
I'm sure there are lots of members here that will be glad to help. BTW...Welcome!
post #3 of 16 Old 07-20-2012, 11:04 AM
ForgedReality's Avatar
Welcome to the forum!
I would NOT use the wimpy factory amp for your sub. Ever. That's for driving the factory speakers, and not only will it not be powerful enough to run everything, it won't supply a clean signal to your sub and you risk damaging your components, including blowing your factory amp from overdriving it.
The factory amp is in the trunk behind the panel in front of the driver's side taillight. You'll need to access your wiring from there for supplying a signal to your monoblock amp for your sub.
I have two 12" JL Audio 12W3v3-2's wired in parallel at 2 ohms on a 1200 watt Hifonics amp and I ****in love it. The battery being in the trunk makes everything super simple to hook up. I'm running 4ga wire directly from the battery. The amp is attached to the back side of my Subthump sealed enclosure, directly behind the back seat.
I ran the wire for the sub level knob under the rear seat, and up through the bottom of the center console where the knob is mounted. Nice and clean.
ForgedReality is offline
post #4 of 16 Old 07-25-2012, 06:23 PM Thread Starter
I looked behind the panel in the trunk and there is no amp. Is it possible that there is no stock amp in the 2012 LT1?
Squills is offline
post #5 of 16 Old 07-26-2012, 12:51 AM
You sure? There ought to be one. Do you have the Boston Acoustics system? If not, I'm not sure where the regular amp would be other than there.
Make sure you remove the plastic panel, and then pull back the carpeted panel too. There is a nut toward the middle rear and a threaded plastic washer cap thing in the floor on the left side. That should allow you to pop it out enough to see behind it.
post #6 of 16 Old 07-27-2012, 04:39 PM Thread Starter
I dont have the Boston system and I looked again today on both sides and there was nothing. There are brackets on the drivers side but nothing there.
Squills is offline
post #7 of 16 Old 07-27-2012, 08:47 PM
Thats what I thought no amp for a non BA system...
post #8 of 16 Old 07-29-2012, 03:39 AM
There has to be or there would be no sound. It's probably smaller and behind the dash or something.
post #9 of 16 Old 07-29-2012, 11:13 AM
Just not going to give up he.. Back in the day the AMP's were in the radio. I will find out where it is..
post #10 of 16 Old 07-29-2012, 12:29 PM Thread Starter
Is there any way to get a signal from the rear speakers for a amp instead of going all the way up to the head unit?
Squills is offline
