audio questions?????? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 23 Old 07-29-2012, 08:41 PM Thread Starter
Poohdogger's Avatar
Smile audio questions??????
Ask me its what I do ........I can answer pretty much any question you may have im also m.e.c.p master certified...
Poohdogger is offline
post #2 of 23 Old 07-30-2012, 08:26 AM
Darkrider's Avatar
I have a question for you - where are you from?
Also, welcome from a fellow autosound enthusiast.
Darkrider is offline
post #3 of 23 Old 07-30-2012, 12:48 PM Thread Starter
Poohdogger's Avatar
Ft.worth,Texas and thank you for the welcome.....
post #4 of 23 Old 07-30-2012, 03:33 PM
I just got a 2012 1LT the other week and I have a JL sub that I would like to add to the system. However I do not have the Boston system in my car and it looks like there is no stock amp. How would you suggest adding to the current system.(There is not an RCA hook up on the stock head unit for an amp)
Squills is offline
post #5 of 23 Old 07-30-2012, 11:12 PM Thread Starter
Poohdogger's Avatar
There are a few ways to do so. The cheap way in which you do the work yourself and go shopping for parts. First you will need the appropriate amp kit that includes all of the cables you will need main power,ground,remote turn on,speaker wire and RCA's also called signal cables as for signal you will need an way to interface thats where an l.o.c or line out convert comes in on this deal you can get signal from the rear deck speakers as for remote turn on you can go to either power port the drawback to getting power from these Ports is that they turn on when the key is on and if you were to turn the radio off there could be a hiss or thump when being turned off or on . There are companoes that have made interfaces that can help out with these two issues Audio Control this company has been building processors for practically every situation check them out look at the lc2 lc 6,7,8
post #6 of 23 Old 08-13-2012, 10:50 PM
BUZZS20122LS's Avatar
Which aftermarket head unit would you recommend specifically for the 5th G. and which dash kit do you like the best?
At what point does the charging system and battery need to be beefed up to power amps?
Are there any really good books which would help make decisions and make it possible for DIY? I saw only one which was the "for idiots" and unless I could browse thru it, I would not buy.
BUZZS20122LS is offline
post #7 of 23 Old 08-15-2012, 04:46 PM Thread Starter
Poohdogger's Avatar
I would stay away from Kenwood a JVC. Reason being is that kenwood was bought out by jvc in April and quality has gone down the tubes especially on kenwoods side. I like pioneer and alpine head units as for install kits for our cars Metra is the one I would use... As for power upgrades the first would be an optima battery the first reason would be weight savings..second would be reliability...third would be because it has half the resistance of a lead acid battery....as far as books go the internet is your Oyster
post #8 of 23 Old 08-16-2012, 02:30 PM
I am currently using rca converters from the pre-amplified lines to jl audio amps. I have jl subs and amps. I like high quality sound. The sound quality using the factory head unit is decent but seems a bit off. Is there much quality increase moving to an aftermarket head unit like an Alpine, or is it not worth the extra time and money for only a marginal gain. Im not sure if the acoustics of the car make it mid-rangy or its the source signal. I had the same equipment in another car and it was a very high quality sound. Thanks
kc690 is offline
post #9 of 23 Old 08-16-2012, 03:40 PM Thread Starter
Poohdogger's Avatar
The quality of sound depends on the quality of the source that it comes from most of the time ill tell my customers the same..... But if you want to keep a factory look I would look into Audio Control products ive used them for years
post #10 of 23 Old 08-18-2012, 10:31 PM
Aight Poohdogger, here goes....I recently had a sub installed in my 2LT with the Boston Acoustics system. The shop simply installed my stuff, using a LOC that is connected to one of the rear speakers. I have a JL 500/1 pushing a JL W6 10 sub. I ebayed a custom box. The box is ported and faces the rear. When I picked it up from the installer, the guy said I hope you like it loud. You couldn't hear anything but bass! I turned the bass all the way down on the head unit, and all the way down on the amp. I have one of the JL Remote bass control knobs. The only thing I bought was the box. I already had everything else and didn't want to sink a ton of money. I just wanted a little more punch to the setup. I really like the quality of the JL stuff I own(I have a stealth box in my Tundra). I just want to lessen the bass the system puts out. I guess I have reached the age where there is such a thing as too loud. I was wondering if the Subthump harness would give me more control? Could you please help?
07Tundra is offline
