Radio Problem - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 08-30-2012, 09:54 AM Thread Starter
PHB
Radio Problem
My wife's 2010 SS has a problem with the radio not recognizing the IPOD. We can have it hooked up and working fine then it will go back to FM radio. When you push the CD/AUZ button it says "no disc inserted", and there's no way to connect to the IPOD. It has done this a few times and then will start working properly again for no apparent reason. I unplugged it replugged it no diff. I took the device, which was not working in the Camaro and plugged it into another car and it worked fine. Anyone else have this problem? We had it reprogramed once when it couldn't remember the date.
PHB is offline
post #2 of 7 Old 08-30-2012, 11:44 AM
Read this. It solved my USB issues....
https://www.moderncamaro.com/forum/el...im-update.html
post #3 of 7 Old 08-31-2012, 10:25 AM Thread Starter
PHB
Thanks good info. Is this a 3 year warrenty item? Car is almost there.
PHB is offline
post #4 of 7 Old 08-31-2012, 02:17 PM
Yes it is, most definitely.... And is why I finally bit the bullet and took it in and got it done, while it was still under the warranty...
post #5 of 7 Old 09-01-2012, 09:06 AM
Had mine updated, they put in a whole new unit! Works like it should have from the beginning!
post #6 of 7 Old 05-12-2017, 09:19 AM
Tricorn61's Avatar
Originally Posted by owlsarepretty013 View Post
I'm new and I'm interested in this topic. Thank you!
My 2012 Black Camaro has a problem when the temperature outside gets in the high 80's / 90's. The CD skips and the radio stations go wacky and start jumping around. I bought it used last Sept so it hasn't really seen the heat of the summer during my ownership yet. Just got a shield for the window hope that helps. Oh yeah the Car is Black inside and out
Tricorn61 is offline
post #7 of 7 Old 08-10-2017, 05:00 AM
Thanks for your page! I hope you will continue to have similar posts to share with everyone! Thank you for sharing them.
hill climb racing 2
hillclimb is offline
