LED Underdash Lighting Installation Question - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 09-17-2012, 06:47 PM Thread Starter
83Hokie's Avatar
Question LED Underdash Lighting Installation Question
I bought the under dash lighting and was expecting some directions but none came ... only the led tubing, the wires sticking out, and a switch. I assume the wires can be tied into the door lights somehow and that the switch is unnecessary, but I guess I'm a little clueless. Its been a long while since I worked on a car, but am genekally mechanically inclined with a little bit of guidance, so..... Can anyone give me some basic guidance on where I need to hook these wires in to make them work when I open the door?
tia
83Hokie is offline
post #2 of 8 Old 09-17-2012, 09:28 PM
PM me I will walk you thur the install....I did mine..
post #3 of 8 Old 09-18-2012, 04:36 PM Thread Starter
83Hokie's Avatar
ok, I think I sent the PM...thanks again
83Hokie is offline
post #4 of 8 Old 04-27-2013, 07:33 PM
Did you get the lights in ok
dreck is offline
post #5 of 8 Old 04-28-2013, 08:37 AM Thread Starter
83Hokie's Avatar
Actually, they are still sitting on my table. Guapo gave me good directions, but it was basically winter and I didn't want to start something and be in the middle of it. So, the lights have sat waiting as I did easier and other needed projects; it is on my near term list now (because I don't have much more in hand to work). There needs to be more 'play' hours in a week.
83Hokie is offline
post #6 of 8 Old 04-28-2013, 08:47 AM
Make sure you zip tie the lights under your dash. The 3M tape will not hold when you start using your heat. If you tie them up, there up for good.
post #7 of 8 Old 04-28-2013, 04:48 PM Thread Starter
83Hokie's Avatar
good suggestion ... ill remember that thanks
83Hokie is offline
post #8 of 8 Old 04-28-2013, 06:14 PM
