Bluetooth - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 41 Old 12-06-2012, 07:23 PM Thread Starter
MidnightSSS's Avatar
Bluetooth
Is there a way to play music through from my iphone through the bluetooth in my SS??
April 2013 COTM Winner
MidnightSSS is offline
post #2 of 41 Old 12-06-2012, 07:33 PM
Yes just pair up your phone and it will play what ever music your phone is playing..
post #3 of 41 Old 12-07-2012, 10:25 AM
Assuming he added the C&C package when he bought it (not standard). Then when pairing he needs to find/use the GMMusicConnect option vs the standard phone pairing option....
post #4 of 41 Old 12-07-2012, 10:33 AM
See You On Course
CUONCRS's Avatar
I used to do the bluetooth for music, but it was always sporadic in connecting, and you couldn't access the songs through the radio interface. I'd have to manually re-connect every time I'd get in after car sitting all day or night.
For me, it's just easier to keep a USB plug in the center console plugged in, and then just plug my iPhone in when I get in. Plus, it charges the phone if needed. Also, song clarity is better with the cable.
2010 Stock IBM 2SS/RS
CUONCRS is offline
post #5 of 41 Old 12-10-2012, 07:59 PM Thread Starter
i only have an aux outlet in mine, and im trying to play pandora radio thru the bluetooth but it wont work, i dont have a usb port
post #6 of 41 Old 12-10-2012, 09:55 PM
J-ROD-210's Avatar
Hey I just did this today.I paired my galaxy3 for bluetooth music and yup,Pandora.I had forgotten how to do it,but I figured it out.I was frustrated at first because I was pairing through handsfree option.You have to pair through music option.
J-ROD-210 is offline
post #7 of 41 Old 12-11-2012, 11:32 AM Thread Starter
im gonna try and figure it out, do u know the steps?
post #8 of 41 Old 12-11-2012, 11:56 AM
See You On Course
CUONCRS's Avatar
If I remember right....
Car on.
In car radio settings, find "Add a device" under "AUX" section.
It will tell you steps to pair.
In iPhone settings, bluetooth, choose pair.
Pick "GM Music" and connect.
That's all from memory (really bad memory), so sorry for not much detail. At least it's a jumping off point.
CUONCRS is offline
post #9 of 41 Old 12-11-2012, 03:09 PM Thread Starter
Car on.
awesome thanks for ur help, i will try it out later tonight!
post #10 of 41 Old 12-11-2012, 03:13 PM
kc0cmj's Avatar
music through blue tooth.
This is out of the owners manual:
Connecting a Bluetooth® Device
Before a Bluetooth device can be connected to the infotainment system, it must first be paired to the system. Not all Bluetooth devices can be paired to the infotainment system. Before pairing the Bluetooth device, become familiar with its user guide for Bluetooth functions. The system only connects to Bluetooth devices that support A2DP (Advanced Audio Distribution Profile) version 1.2.
Pairing Information:
Up to five devices can be paired to the system.
The pairing process is disabled when the vehicle is moving.
The infotainment system automatically links with the first available paired device in the order the device was paired.
Only one paired device can be connected to the infotainment system at a time.
Pairing should only need to be completed once, unless changes to the pairing information have been made or the device is deleted.
Bluetooth Setup Menu
The Bluetooth Setup menu can be accessed with or without a device attached to the USB port.
To select the Bluetooth Setup menu when a device is attached to the USB port and active:
1.
Press the MENU/SELECT knob while in the iPod, Zune, PFD, or USB device main menu.
2.
Select Bluetooth Music Setup.
To select the Bluetooth Music Setup menu when a device is not attached to the USB port, or when a device is attached to the USB port but not active:
1. Press the CD/AUX button until AUX is the active source.
2. Press the MENU/SELECT knob.
3. Select Bluetooth Music Setup.
To select the Bluetooth Music Setup menu when a Bluetooth device is connected and active:
1. Press the MENU/SELECT knob.
2. Select Bluetooth Music Setup.
Pairing a Device
1. Select Connect To New Device from the Bluetooth Music Setup menu.
2. The system asks a series of Yes/No questions to determine what type of device is being paired.
3. After the system determines what type of Bluetooth device is being paired, the Bluetooth device will need to be put into discovery mode.
4. Some devices may require a PIN number in order to complete the pairing process. Locate the device named “GMusicConnect” in the list on the Bluetooth device and follow the instructions on the device to enter the four digit PIN number provided by the Infotainment System.
Connecting to a Device
Once a device is paired to the Infotainment System, it can be connected to the Infotainment System.
To connect a paired device when no other device is connected to the Infotainment System:
1. Select the Select Device option from the Bluetooth Music Setup menu.
2. Select the new device.
To connect a paired device when another device is connected to the Infotainment System:
3. The active device is disconnected from the system and the new device is connected.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
