electric seat heaters - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 01-23-2013, 01:55 AM Thread Starter
c192ps's Avatar
Lightbulb electric seat heaters
Just out of warrenty my drives seat heater died. For most people this would not happen, however with my bad back I use the heated seat year round and when it was working it did a better job than the pain pill the DR gives me. I did contact GM and they were surprised that the heated failed early. GM did try to help, but being I never have ever taken the car to the dealer for anything that there was nothing they could do. The reason that I will never take my car to the local dealer is that they have a very poor rep around town. I did talk to the GMC dealer next door which has a highly rated service department and one of the mechanics told me it takes about an hour to change the heating elements. So later this week I will order the heating elements and a new seat cushion being the seat will be apart. As a backup the mechanic I talked to is a longtime friend of my brother, so if problems arise one phone call should solve the problem.
c192ps is offline
post #2 of 5 Old 01-23-2013, 08:16 AM
c192ps,
I am sorry to hear that your heated seats are no longer working for you. Feel free to contact me with any concerns or questions you may have.
Ashley
Chevrolet Customer Assistance
post #3 of 5 Old 01-23-2013, 10:43 AM
BBQdDude's Avatar
I see by your profile that you have an SS with DRL/fogs.
Check to see if the DRL/Fogs are working. If not that is the root cause to why the seat heater won't work.
Just went through this myself .
BBQdDude is offline
post #4 of 5 Old 01-27-2013, 08:46 PM
Yellow 2SS's Avatar
You need someone either at a dealer, or a mechanic with a scan tool capable of looking at the inputs and outputs of the BCM. My seat heater sometimes will turn on but won't go off. Or won't turn on at all. This affects both seats when it malfunctions. I have traced it to be a software glitch in the BCM (body control module). The reason I suspect this is that the scan tool shows the inputs from both switches working properly, and I can acutate the outputs to turn on the seats via the scantool. Usually happens while driving. If I pull over and shut the key off for a few minutes then turn the ignition back on, all is fine. It hasn't happened in a while, and now the car is sleeping so I can't verify if it still happens. I would like to know how you make out with the repair. Also, the heater elements can be checked with an ohm meter to see if they have continuity. Furthermore, there are many other things to consider before just replacing the heater part. Like bad relays, etc...
Randy
#4645
Yellow 2SS is offline
post #5 of 5 Old 01-27-2013, 09:12 PM
Yellow 2SS's Avatar
The DTC for a failed seat heaters are as follows:
Driver Heated seat element control-
open or high resistance - B2425 0D
resistance between terminal 1 and 2 should measure between .5 - 5.0 ohms
check once with seat un occupied and again with someone sitting on cushion.
My guess is that it is the k29 control module if both the back and bottom heaters are not functioning.
There is alot to this system. You should not just throw parts at it to fix it.
The heaters used in these seats are the same for alot of other gm products around the globe. It's probably not the heater elements.
Also check for any objects that may have gotten under the seat near the wiring and damaged it.
Randy
Edit: the heaters are in series. So if the cushion is bad, the back won't work and vice versa.
#4645
