2013 Camaro Electrical Mods Issues - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 21 Old 07-16-2013, 06:20 AM Thread Starter
Has anyone had issues with there lighting mods on a 2013 Camaro?
I have JDP harness, LED Plasma DLR's and AAC LED marker lights. I have been having issues. Just seeing if its only me. My dealer has blamed all my issues on my lighting mods..
post #2 of 21 Old 07-16-2013, 02:29 PM
MidnightSSS's Avatar
what problems are u having?
April 2013 COTM Winner
MidnightSSS is offline
post #3 of 21 Old 07-16-2013, 03:01 PM Thread Starter
Tons. Just looking to see if any one else is having any. Too extensive to post publicly
post #4 of 21 Old 07-16-2013, 08:52 PM
CyCam1's Avatar
I would have to agree with the dealership. If you put on many electrical mods you probably have a short somewhere. Could be bad grounds. If it is effecting other systems not related then you have a crossed wire somewhere. Start by unplugging each new harness and then put them back one system at a time. Check to see if they work before doing another harness. One of the setups is bad.
CyCam1
CyCam1 is offline
post #5 of 21 Old 07-16-2013, 11:46 PM
CyberPunk223's Avatar
yep, these cars are funny, I had some cheap xentec HID's and had multiple codes for traction control and reduced engine power when the 6volt DRL's were on.. Got some good quality HID's and problems went away.
thinking about it, the new HID's could still be causing damage to my electronics, but I'm not having any codes so i'll stick with them.
Your low voltage LED's may be screwing up the computer.
CyberPunk223 is offline
post #6 of 21 Old 07-18-2013, 05:48 PM
83Hokie's Avatar
I only have two of my Oracle / AAC LED marker lights in (front), but no problems ... once I get my September inspection, I will probably try the back two ...
83Hokie is offline
post #7 of 21 Old 07-19-2013, 06:09 PM
i have plasma leds for my DRLS will that screw up my computer??
post #8 of 21 Old 07-20-2013, 06:56 AM Thread Starter
Thanks all for your input, I guess I will remove my harness and DLR Bulbs and see if the system will reset. One of the things quits working is the remote start button on the key fob. The car will start but not stop or unlock the doors with the key FOB. I have to use the key..
post #9 of 21 Old 07-20-2013, 07:40 AM
Aftermarket HIDs can cause all kinds off issues due to electrical noise from the ballast.
post #10 of 21 Old 07-20-2013, 09:05 AM Thread Starter
Yea I know. All the same lighting mods were on my 2011/LT1 as well with issues, except the DLRs were not the same bulbs.
