Help with JL 400 Amp - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 1 Old 09-24-2014, 10:35 AM Thread Starter
I installed the JL 400 and FARK kit keeping the stock BA speakers and have a problems:
1. First time I turned it on, no power. I read in the JL manual that some instances you have to supply 12V to the "REMOTE" terminal with jumper? I used a short 8 gage wire connecting it to the main 12v terminal on amp, is this ok?
2. When ignition is turned off the amp light stays on, I ran 12v from amp to battery as per directions.
3. What amp settings are you guys using?
Thanks for your help
DonTFG is offline
