I need to find a diagram. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 2 Old 01-11-2010, 04:12 PM Thread Starter
ThunderSS's Avatar
Looking for the Tach Output lead behind the dash.
also need the Vehicle Speed Signal Output from the ECU
Can anybody help out here?
Thanks
Daniel
____________
2010 Camaro RS/SS HKE Forged 416 CID Stroker /2005 Silver Cadillac Escalade
http://www.fquick.com/ThunderZ28
510 HP/482 Ft. Lbs
ThunderSS is offline
post #2 of 2 Old 04-03-2010, 10:10 PM
Yellow 2SS's Avatar
Thanks
Daniel
____________
VSS INPUT to the ECU is Gray/Black,X1 Pin71 (V8 manual) available at trans tail housing or ECU
Cylinder 1 Ign coil Purple,X2 Pin70 (V8) At ECU or Coilpack. Can be used for tach signal depending on intended use.
There are NOT seperate signals at the cluster, all signals are VIA databus to cluster.
Use extreme caution when testing or tapping into these circuits!
You must use high impedance test equipment or component damage will result!
You have been warned!
The 5th gens have as much wiring as a BMW, be sure you are familiar with proper procedures to work on modern automotive electrical systems.
Randy
#4645
Yellow 2SS is offline
