Careful with them Exhaust Band Clamps! - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 15 Old 04-13-2010, 09:28 PM Thread Starter
RedJewel2SS's Avatar
i got bored after work, went out to my garage and checked the torque on all my exhaust clamps so no leaks occur. i just got a new torque wrench so i was playing with it.
in the process i snapped the bolt on one of my exhaust band clamps
i was about to go to ACE hardware to find another bolt, but luckily i had an extra clamp laying around in my garage! good thing i'm a pack rat and don't throw anything away.
must be my huge strong muscles... i did do this after working out
Gone but not Forgotten!
RedJewel2SS is offline
post #2 of 15 Old 04-14-2010, 07:32 AM
Rodimus Prime's Avatar
Band clamp? Those fancy looking things? I still rock the factory clamps. I'm such a cheap wad.
No reason was specified.
Rodimus Prime is offline
post #3 of 15 Old 04-14-2010, 07:42 AM
demonspeed's Avatar
They are very easy to break. Easy on the muscles, Arnold.
www.fquick.com/demonspeed
Present: '02 SS #7146
demonspeed is offline
post #4 of 15 Old 04-14-2010, 07:43 AM Thread Starter
the "accuseal" band clamps came with my axle-back exhaust, and ARH header kit. when i combined the 2 i had one extra clamp leftover
they are prone to leaking, and a PITA to keep perfectly sealed at each pipe connection. they have the 2 pipes have to be connected far enough in, and the clamp has to be properly aligned so no leak occured.
then BAM! i torqued them all to factory specs and i sheared one of the bolts!
post #5 of 15 Old 04-14-2010, 07:55 AM
I TOLD YOU TO QUIT POSTING PICTURES OF ME ON THE INTERWEBZ!!!
post #6 of 15 Old 04-14-2010, 08:11 AM
el ess X's Avatar
(This one time, at band clamp....) Sorry, couldn't resist.
Are they stepped band clamps? I had great success using stainless stepped band clamps when I got my CME tips chromed on the 4th gen. Fits the pipes better with no leaks. Got them from a place that sold school bus parts of all things. MUCH cheaper than using the "brand name" clamps and accomplised the same thing.
Another "tip" as it were, if the ends of the outer pipe aren't split-tailed, you can cut a short slot on each side (without going past the inner pipe depth and band clamp coverage area causing a hole) to help allow the pipe to be clamped down further.
Just an idea.
And Rodimus, that's not you, that's Ahhnold. Here's the one of you:
el ess X is offline
post #7 of 15 Old 04-14-2010, 08:27 AM
Just an idea.
I shaved my happy trail since that pic though. That makes me sexy!
post #8 of 15 Old 04-14-2010, 08:31 AM Thread Starter
this is what they look like, and yes the outer pipe at each connection is split.
post #9 of 15 Old 04-14-2010, 08:50 AM
el ess X's Avatar
This was what I was talking about. For the life of me I can't remember where I got them. That was 7 years ago, and I'm sure they've increased band clamp usage all over the place by now so you can get them pretty much anywhere.
el ess X is offline
post #10 of 15 Old 04-14-2010, 09:32 AM Thread Starter
yeah i'm sure those aren't hard to find, and would help in preventing leaks. i don't have anymore leaks now since i torqued and adjusted them all ( at Midas for a crumy install job)
