New l99 weight reduction results. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 27 Old 10-24-2010, 04:02 PM Thread Starter
Rodimus Prime's Avatar
Originally....I weighed my car on a certified CAT scale. Nobody in the car, 1/2 tank of gas exactly, as the car comes from the factory. No ground effects, standard 20" wheels, no rs package (not that it matters).
Front axle weight was 2020 lbs
rear axle was 1840 lbs
for the combined weight of 3860 lbs.
Today I weighed it again
Front axle was 1980
Rear axle was 1700
Total weight 3680 with 1/2 of gas again.
I still have the stock front wheels on and expect to lose a little bit more when I get my 18" zo6 wheels on there.
Anyways so far Ive removed an easy 180 lbs. I guess it will be at least a solid 200 lbs when I get the new fronts on.
No reason was specified.
Rodimus Prime is offline
post #2 of 27 Old 10-25-2010, 09:18 AM
RedJewel2SS's Avatar
and your not going to spill the beans on how you lost 200 lbs???
Gone but not Forgotten!
RedJewel2SS is offline
post #3 of 27 Old 10-25-2010, 10:48 AM
Kalenn's Avatar
Jenny Craig? NutriSystems? Weight Watchers?
"Ladies and gentlemen, take my advice. Pull down your pants... and slide on the ice." Sidney Friedman
"A hero is made in the moment, not from questioning the past or fearing what's to come."
Kalenn is offline
post #4 of 27 Old 10-25-2010, 11:41 AM
bulimia? anorexia?
Black 2010 2SS/RS Automatic, Sunroof
Independent Amsoil Dealer- PM me for details
blackknight is offline
post #5 of 27 Old 10-25-2010, 02:19 PM Thread Starter
lol, I posted it but forgot to hit reply before I turned off my laptop. Anyways...
Full list of mods done so far.
Long tube headers to high flow cats to custom x-pipe to replace resonator. Mufflers removed and replaced with straight pipes w/ stock tips.
Replaced Brembos with v6 brakes.
18" knock off z06 wheels out back.
sway bars and springs changed out.
front bumper support removed.
rear bumper support removed.
Yank 3600 converter.
Removed some extra plastic from inside the front fascia by the radiator.
Removed air dam.
Removed tire inflator kit.
Removed spare tire cover and carpet.
Removed top piece of metal that sits over the battery.
Removed floor mats.
Removed center speaker from dash.
Removed both engine covers.
Replaced stock intake for New Era OTR intake.
Removed hood liner.
Make sure washer fluid is empty.
Added Nitrous plate kit from Nitrous Outlet....weight is without bottle or nano bottle.
Added a trans cooler.
I plan to run it with less than 1/4 tank tomorrow. Seriously going for an 11.9 on stock front wheels. I think it would be easy with lighter fronts.
post #6 of 27 Old 12-02-2010, 10:59 AM
Superman09's Avatar
I understand all of your mods except for the V6 brake swap. Why would you want the V6 brakes on an SS?
Superman09 is offline
post #7 of 27 Old 12-02-2010, 11:13 AM Thread Starter
To run smaller wheels for lighter weight and bigger tires for better traction.
post #8 of 27 Old 12-02-2010, 01:13 PM
I thought about doin this I would like to rock some 18's instead of 20's, very cool!
Swissbliss is offline
post #9 of 27 Old 12-02-2010, 02:43 PM
if i did the v6 brake swap, i would only do it to the rears.
post #10 of 27 Old 12-02-2010, 03:03 PM Thread Starter
The fronts are the problems. You can "supposedly" fit 17s over the stock rears.
