Fluids - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 10-25-2010, 11:48 AM Thread Starter
Fluids
I just spent $35.08 for 1 qrt. of the rear end fluid plus an additional $12.54 for the additive whatever that is and $7.68 per qrt. of trans fluid. What is this stuff made of and were can I get an equivalent or better fluid at a better price?
timidtiresmoker is offline
post #2 of 5 Old 10-25-2010, 04:04 PM
RedJewel2SS's Avatar
Mobil 1 diff fluid is about $10 per qt. and does not require the additive
you'll need 2 quarts, because the diff hold just over 1 qt.
here's what it looks like
the LS stands for limited slip, meaning it is formulated specifically for limited-slips, which is why the friction modifier additive is not required.
Gone but not Forgotten!
RedJewel2SS is offline
post #3 of 5 Old 10-25-2010, 04:19 PM
Trott's Avatar
Mobil 1. Best bang for the buck.
Trott is offline
post #4 of 5 Old 10-25-2010, 08:42 PM
WRAITHSS's Avatar
I would say for the best Royal purple. For your trans, and rear diff. Engine Mobil 1 15,000 mile one.. Cant go wrong.
Chance Favors The Prepared Mind!
Originally Posted by el ess X View Post
Look at it this way, if you have "Camaro" written on your car somewhere, you're already starting with a great platform!!
WRAITHSS is offline
post #5 of 5 Old 10-26-2010, 08:04 AM Thread Starter
Thanks for opinions, I have been using amsoil products in my 113ci Harley for years and mobil 1 in my vehicals with excellent results. I will check into exactlly what chevy demands be put into the rear end of the camaro and switch to something priced fairly.
