Power Steering Pump Noise Question - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 01-01-2011, 10:45 PM Thread Starter
I've had my car stored for the past couple of months due to Winter, but I received some new headers for xmas from the wife and I installed them this weekend. While I was checking for exhaust leaks I noticed a whinning noise coming from what I believe to be the power steering pump. When I turn the wheel slightly in either direction the noise stops. The question i'm hoping someone can help with is: Is this normal?
cwalms is offline
post #2 of 7 Old 01-02-2011, 11:40 AM
Checked the fluid?
post #3 of 7 Old 01-02-2011, 05:20 PM Thread Starter
Originally Posted by sdk View Post
Checked the fluid?
yep, it looks good.
cwalms is offline
post #4 of 7 Old 01-02-2011, 05:28 PM
el ess X's Avatar
Warranty? Then to the dealer it should go. Let them fix it.
FWIW, I had a whiny ps pump on the 06 GMC truck. Not real bad, but I knew it was there and didn't like it. Which GMC/Chevy trucks in that era was known for that issue. Drained out the fluid and replaced it with synthetic fluid and no more noise. Not saying this is what your issue is though...
el ess X is offline
post #5 of 7 Old 01-02-2011, 08:04 PM Thread Starter
I may try to replace the fluid to see if that works. If not, I'll bring it to the dealer.
thanks for the feed back.
cwalms is offline
post #6 of 7 Old 01-03-2011, 05:51 AM
el ess X's Avatar
Be careful doing your own corrective maintenance while the car is under warranty because if it IS a real problem, they could be azz monkeys about it and say since you mucked with it, it's no longer under warranty and you'll eat the costs. Just a thought.
If'n it were me, I'd take it directly to the dealer and let THEM document it, and tell me if it's an issue or not.
el ess X is offline
post #7 of 7 Old 01-03-2011, 07:17 PM Thread Starter
Thanks for the input. I'll probably do just that.
cwalms is offline
