Rear End Popping - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 15 Old 07-31-2011, 09:24 PM Thread Starter
ddavis4035's Avatar
Rear End Popping
I noticed somthing today that kind of has me worried. When i backed out of my garage and turned the wheel it felt and sounded like a "popping" noise came from the rear end. If you know what a truck sounds like if you try to turn really sharp on asphault while in 4 wheel drive, it was that type of sound. Anyone else heard this? car only has 1000 miles on it....hope i didnt get a lemon haha
2011 Camaro 1LT RS. Summit White. Cyber Gray Metallic stripes. Heritage Grille. Stay tuned...more to come!!
ddavis4035 is offline
post #2 of 15 Old 08-01-2011, 08:05 AM
Keep an eye/ear on it, I haven't heard any issues, but things, always happen,
if it happens again take it to yo dealer, wright down the dates & times it happens
hope that help's, sorry if not.
I had my rear-end gear go out on me truck w/ only 500 + something miles ,
I was the only person that had a issue like this for a couple years me dealer stated,
years later from their dealership, they still had no one have me issue w/me rear-end.
post #3 of 15 Old 08-01-2011, 06:47 PM
Take it back to the dealer ASAP, it needs the limited slip additive installed. Mine did this early on last year but found a bad bearing as well and had to be rebuilt. Most of the common noise's from rear end are because of lack of or not enough of the additive.
Hope this helps.
JW
post #4 of 15 Old 08-01-2011, 07:03 PM
Buzz's Avatar
Agree. ASAP. But see if can get to reproduce the noise first. Then have them get in the car with you.
Buzz
2010 Synergy Green 1LT
Buzz is offline
post #5 of 15 Old 08-14-2011, 07:52 PM
Bill F's Avatar
Any resolution? Mine is doing this as well. Pops once when I start to back up and again when I start moving forward. Almost like the rearend is binding then unbinding.
2011 2LT/RS CGM
Bill F is offline
post #6 of 15 Old 08-14-2011, 09:04 PM Thread Starter
ddavis4035's Avatar
There is a TSB per Chevrolet on the issue. It happens with both the corvettes and camaros. Something to do with the posi trac in the rear end. Easy fix, take it in to your dealer, tell them u know theres a tsb on it and the resolution is some type of additive for the rear end fluid. Dropped it off when they opened and picked it up around lunch. Didnt cost a dime. Hope this helps!!
post #7 of 15 Old 08-14-2011, 09:35 PM
Bill F's Avatar
Thanks!
2011 2LT/RS CGM
Bill F is offline
post #8 of 15 Old 09-01-2011, 03:11 PM
Bill F's Avatar
So I went to the dealer today for the car's first oil change and brought up the issue of the popping noise. I was told by the service "advisor" that the tech looked everything over and checked the driveline. Everything looked normal and that a clunking noise is normal when a car is shifted from park to drive. I told her I have an M6, not automatic, and it "pops", not "clunks". I then asked if the tech heard the noise and she said no, but everything was fine. I laughed, took my keys back, and left. I have an appointment at another dealership to have this looked at. Does anyone happen to have the TSB# that applies to this? Thanks for the help!
2011 2LT/RS CGM
Bill F is offline
post #9 of 15 Old 09-01-2011, 08:29 PM Thread Starter
ddavis4035's Avatar
I found this that another member posted on another thread....print this and take it in and tell them to take care of it haha
PI0137A: Rear Axle Chatter Type Noise on Low Speed Turns - (Feb 24, 2011)
Subject:
Models:
2010-2011 Chevrolet Camaro
Equipped with Limited-Slip Differential (RPO G80)
This PI is being revised to add the 2011 model year. Please discard PI0137.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment on a chatter-type noise from the rear of the vehicle while making low speed turns.
This condition may be caused by a slip/stick of the posi-traction clutch plates. As the plates slip and stick, a jumping or jerking feel occurs, accompanied by a chatter noise.
Recommendation/Instructions
Important: Prior to adding the limited-slip axle additive, the bottle MUST be shaken vigorously for at least one minute to mix the additive thoroughly, then immediately poured into the differential.
Drain and refill the rear differential with new fluid, GM P/N 89021677 (in Canada, use P/N 89021678) and additive, GM P/N 1052358 (in Canada, use P/N 992694). Refer to the Differential Oil Replacement procedure in SI.
Once the differential fluid has been changed, the vehicle must be driven in eight tight figure eight maneuvers to heat the fluid and allow the additive to be worked into the clutch plates
post #10 of 15 Old 09-01-2011, 08:48 PM
Bill F's Avatar
Awesome, thanks! I'll take this to the other dealership. The funny part is, the dealership I bought the car from specializes in Camaros and Corvettes. Wonder how much $$$ they have cost less savy owners.
2011 2LT/RS CGM
Bill F is offline
