Change oil message - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 10 Old 10-27-2011, 09:48 PM Thread Starter
Question Change oil message
Change oil soon message displays when I start the car, even though I just changed the oil. can someone tell me how to get this to go away? Appreciate it!
Ladycamaro is offline
post #2 of 10 Old 10-27-2011, 10:30 PM
You have to reset the Oil Life Display when the oil is changed because it doesn't do it on it's own. Here's how to reset the system:
1. Turn the ignition to ON/RUN with the engine OFF.
2. Fully press and release the accelerator pedal three times within five seconds.
If the "Change Engine Oil Soon" message disappears...the system is reset.
post #3 of 10 Old 10-28-2011, 10:24 AM
Weird I have to use the menu select button then click reset that's located on the turn signal lever.
JULY 2013 M.O.M winner!
Strick is offline
post #4 of 10 Old 10-28-2011, 10:35 AM
kc0cmj's Avatar
can be done either way.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #5 of 10 Old 10-28-2011, 01:29 PM
ユキヒョウ
Nancygrl's Avatar
Either way will work. I reset from the turn signal lever.
2019 1SS/1LE
Nancygrl is offline
post #6 of 10 Old 10-28-2011, 04:38 PM
and to be clear for the OP, cycle the DIC display so it shows the oil life % remaining screen, press the button on the end of the stalk and it will prompt on the display: Reset Oil Life YES or NO (yes is the default) press the button again and watch the magic happen.
post #7 of 10 Old 10-28-2011, 05:36 PM
Supporter of common sense
OverAnxious's Avatar
It's in the manual
OverAnxious is offline
post #8 of 10 Old 10-28-2011, 07:15 PM
Originally Posted by OverAnxious View Post
It's in the manual
post #9 of 10 Old 11-06-2011, 09:40 AM
Stating the obvious...because that's my specialty...not everyone has a manual.
I just gave the extra one that I had to a friend of mine that bought a used 2010 SS with no manual in it.
post #10 of 10 Old 11-06-2011, 10:42 AM
What happened to Ladycamaro... she has not responded back
Ladycamaro plz post on our new members thread so we can give you a warm welcome to our sight
Ohh.. don't for get pics of your camaro, we here luv pics
