HID Headlight Life Span - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 11-24-2011, 08:44 AM Thread Starter
69-er's Avatar
Does anyone know what I should expect on how long HID headlights last?
I am starting to slowly collecting used parts I feel will wear and/or be be damaged during the lifetime of the car. I figure it will be cheaper in the long run if I collect them now instead of waiting until they go bad. In several years these parts may be unavailable from the dealer.
So far, I have the floor mats and arm rests. I am concentrating on mostly wear items. I might even look for some Brembo brake pads as I hear they are very expensive.
69-er is offline
post #2 of 5 Old 11-24-2011, 09:49 PM
Darkrider's Avatar
HID's are pretty common across many manufacturers. The bulbs last considerably longer than normal bulbs (3000 hours or so - around 90,000 est. miles). I would expect that with their constant proliferation throughout the auto industry, that replacement lamps (and ballasts) should be around for a very long time.
Darkrider is offline
post #3 of 5 Old 11-24-2011, 11:12 PM Thread Starter
69-er's Avatar
So you're saying the bulbs and ballasts are universal, like halogen bulbs?
69-er is offline
post #4 of 5 Old 11-25-2011, 06:37 AM
well
as always in life
things are a bit more complicated
as long as you switch them on and have them on over a longer period of time, they may reach the above given lifetime
but if your car is equipped with headlights, that turn automaticly on and off (if you pass under a bridge etc.), and you come across such events more often, this is said to shorten the lifetime dramatically!
highlander is offline
post #5 of 5 Old 11-25-2011, 12:15 PM Thread Starter
69-er's Avatar
Hmm, maybe I should stop giving other Camaro drivers a "hello" flash when I see them on the road. I wondered if there was a stress of sorts on start up of the HID system.
69-er is offline
