DRL Bulb - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 19 Old 09-20-2012, 09:43 AM Thread Starter
MidnightSSS's Avatar
DRL Bulb
How do u get the bulb out of the socket, i cant seem to get it, ive pushed and pulled and nothing, wut am i doing wrong?? thanks guys
MidnightSSS is offline
post #2 of 19 Old 09-20-2012, 11:15 AM Thread Starter
anyone? i appreciate the help
post #3 of 19 Old 09-20-2012, 12:01 PM
Mr. iNCREDIBLE's Avatar
I presume you mean the RS ones in the fog light area?
it's a twist. 90 as I recall when I put the plasma LEDS in there, it was from side to bottom, no push in, just a twist, but it is tight..
Mr. iNCREDIBLE is offline
post #4 of 19 Old 09-21-2012, 10:54 AM
Yup, twist counter-clockwise then pull....
post #5 of 19 Old 09-24-2012, 12:08 PM Thread Starter
Yes i have a 2012 1SS/RS and i wanna put an LED bulb in there, but everytime i try to pull out the bulb if feels like im gonna break it lol, does just the bulb come out? or the plastic piece or housing beneath it as well? thanks
post #6 of 19 Old 09-24-2012, 12:54 PM
You can remove just the bulb. You HAVE to twist it about 90 degrees counter-clockwise FIRST before attempting to remove it. It is a very tight fit for both the twisting and removal part....
post #7 of 19 Old 09-24-2012, 06:39 PM Thread Starter
so which should i do? because im looking to get those P13 bulbs?
post #8 of 19 Old 09-24-2012, 07:16 PM
it's not hard, you just seems a bit timid to do it.
I did my swap in the dark laying in my driveway with my hand up under the car, no light, no view of what I was turning, just feel and instinct..
turn it until it stops turning and pull, if it doesn't come you haven't turned it enough, need some elbow grease and a little strength in your hands..
ain't hard son, probably one of the easier things to change on this car.
post #9 of 19 Old 09-25-2012, 10:14 AM
Where are you located? I could do them for ya... Or if not near me another member in your area would help I'm sure....
post #10 of 19 Old 09-25-2012, 11:13 AM Thread Starter
ok i will give it another try, does anyone know which led bulbs i need to order?? i heard i may have 2 types, i have a 2012 ss, and looking to get that plug and play harness to connect the DRLs with the headlights,
I appreciate it but im in NY
