Rear trunk water leak - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 25 Old 05-03-2013, 08:39 AM Thread Starter
RS_2LT_SummitWhite11's Avatar
We have had some pretty heavy downpour the past few days down here in South Florida. I just came out this morning and opened the trunk to my 11' 2LT coupe and found a water puddle sitting on top of the Camaro mat. I am unsure as to where the leak could be coming from. It also got the carpet wet underneath it as well. Some of it had evaporated - however the water stain on the mat seems to be larger than the exposed water puddle which leads me to believe this was a rather large leak. Any one else have this problem?
post #2 of 25 Old 05-03-2013, 12:39 PM
It is unlickly it came in around the trunk to body gasket since it is so high, I have heard that a loose fastener under the rear spoiler on the trunk can allow water to seep under the mountings and leak inside.
post #3 of 25 Old 05-03-2013, 01:25 PM
kc0cmj's Avatar
Nothing common... No bulletins from GM that I can find.. It would be under warranty, I would have the GM dealer just do a diagnostic, they can check for water leaks.. shouldn't be too hard to let water run on it and fold the seat down to see where it comes in at.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #4 of 25 Old 05-05-2013, 06:51 PM
Hello RS_2LT_SummitWhite11,
So sorry for that surprise in your vehicle, thatís not something we would like waiting for you before you take off. Have you had the chance to take it to a dealer by any chance? If not, I recommend doing so. If you like I can assist you here. I would need some information from you to get started so just let me know if I can help.
Reggie B.
Chevrolet Customer Care
post #5 of 25 Old 05-05-2013, 09:01 PM
I had the same issue but it was from the sunroof drain lines coming apart inside the trunk. I had to wire tie them together to stop them from separating. If you have a sunroof look at the drain lines.
JULY 2013 M.O.M winner!
Strick is offline
post #6 of 25 Old 05-06-2013, 05:14 AM
83Hokie's Avatar
Question
I have a sunroof, where am I looking for these drain lines?
83Hokie is offline
post #7 of 25 Old 05-06-2013, 07:36 AM
Pop the trunk look up inside the left and right side you will see two plastic hoses on both sides. You kinda have to stick your head inside of the trunk. Mine were easy to see cause they were separated.
Strick is offline
post #8 of 25 Old 05-06-2013, 09:30 AM
I had forgotten about those, your probably correct!
post #9 of 25 Old 05-06-2013, 11:22 AM
skuttduck's Avatar
This might help.
I took this picture during the heads up display install. The drain holes are the little rubber grommets in the trunk area. The water drains out behind the tail lights.
skuttduck is offline
post #10 of 25 Old 05-06-2013, 12:32 PM Thread Starter
Reggie B.
Thank you for your reply. I will send you a PM.
