gm front spoiler/lip - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 09-15-2013, 06:33 PM Thread Starter
rydahog's Avatar
i looked around on gm parts sites,,,cant seem to find these items...i need the part number for the gm front spoiler/lip mounting bracket and template? the rivets i can get. The other parts as i said i cannot find. thanks for any help. this is for 2012 SS
rydahog is offline
post #2 of 5 Old 09-17-2013, 01:31 PM Thread Starter
rydahog's Avatar
parts i need..
looking for this bracket for front lip/splitter and 2 smaller side mounting pieces and if possible the template to install this. Dealer tells me i cannot get this without buying the WhOLE GFX kit...$1200 thanks for looking
Name:	spoiler bracket.jpg
rydahog is offline
post #3 of 5 Old 09-17-2013, 05:27 PM
83Hokie's Avatar
wow!!!! that's awful ... do you know what they look like? Anyway, what I am getting at is, is there any chance you could have them fabricated? I sure thought you could get a GFX Splitter without the whole kit somewhere ... not that it is a great solution
83Hokie is offline
post #4 of 5 Old 09-19-2013, 01:47 PM Thread Starter
rydahog's Avatar
well the good news is this. i found a set of mounting brackets like shown in pict for front of fascia, so thats good, and the guy tells me that these parts when held/taped to facia line up perfectly with tabs that are on it....so NO need for a template...the bad part is that i cant find and dealer wont sell the 2 side mounting brackets for the splitter...so i think i will look around for an alternative ,these pieces appear to be approx 2"x3" with a 1/4" offset. i think i found a very close fit for this,,and hopefully with some double back sticky tape will do the trick.http://ep.yimg.com/ca/I/yhst-3087258..._2272_13097937 this part Z bar i can cut to fit.
rydahog is offline
post #5 of 5 Old 09-21-2013, 02:42 PM
GM offers no hardware for any of their accessories separately, you may be able to find the brackets used somewhere but even then probably not easy to find.
BluePhoenix is offline
