Sunroof issues - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 9 Old 10-14-2013, 09:08 AM Thread Starter
RS_2LT_SummitWhite11's Avatar
Sunroof issues
Wondering if any of you had similar issues as to what I am experiencing. This started a few months after I purchased the car in May 2011. I have just kept forgetting to take pictures to post until now. If you look at the plastic around the cables from where the sunroof has been rubbing against - you will see how it has stripped and is showing wear. Should this be a concern or is this a warranty issue?
post #2 of 9 Old 10-14-2013, 10:54 AM
83Hokie's Avatar
I would hope so ... I haven't had any of that
83Hokie is offline
post #3 of 9 Old 10-14-2013, 01:23 PM
kc0cmj's Avatar
I would warranty that under the 3 year 36,000 mile at my shop!
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #4 of 9 Old 10-14-2013, 01:36 PM
LuSe4's Avatar
Take it in and when they do fix it, keep it lubed.
I am going to make sure mine has a little grease on it tonight.
-2013 Summit White over Inferno Orange 2SS RS LS3-
-2005 Bermuda Blue Tahoe (daily driver)-
LuSe4 is offline
post #5 of 9 Old 10-14-2013, 07:48 PM
RS_2LT_SummitWhite11,
What are your plans for getting this looked into? We want to make sure we are there with you through that process.
Sarah (Assisting William)
Chevrolet Customer Care
post #6 of 9 Old 10-15-2013, 10:42 AM Thread Starter
I'll be bringing the car in within the next week or so to get looked at.
post #7 of 9 Old 10-17-2013, 07:45 PM
Sounds good,
Any updates you can provide would be greatly appreciated. We're also here via PM if you need additional assistance.
William R.
post #8 of 9 Old 10-21-2013, 06:33 AM
ModernCamaro.com Sponsor
Tampa Tuning's Avatar
Ive never noticed that. Ill have to take a look on mine. That's worn out pretty good.
Is that a part/strap that needs grease?
Tampa Tuning is offline
post #9 of 9 Old 11-13-2013, 07:22 PM Thread Starter
They ended up replacing the sunroof deflector and added lube. All is well and looks so much better now!
Not only that - my lower front dam was missing two plugs on the front passenger side that were used to hold it on. They ended up throwing some new ones on it to secure it at no charge!
