Cruising oil temperature? - Page 2 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #11 of 14 Old 04-24-2014, 01:15 AM Thread Starter
427cubicinches's Avatar
Originally Posted by sebian View Post
I just double checked my oil temps last night on the ride home.
Outside temp: 90F
Stop and Go Traffic: 225F - 235F
Cruising 70-80 mph: 210F - 215F
I will check the coolant temps tonight, as the outside temp will be about the same.
Originally Posted by 83Hokie View Post
I looked at mine again on a little longer drive ... was just a little bit above the 210 line, so I'm guessing 215ish
Hmm.....some cars cruising oil temps running 10-15 degrees cooler than others.
Our outside temp has not gone above 70F.
Thanks guys
427cubicinches is offline
post #12 of 14 Old 04-24-2014, 01:29 PM
Outside temp last night was 87F-89F.
Coolant temps:
Stop and Go: 195F - 205F (AC Off)
Cruising 70-80mph: 180F - 185F Mostly steady at 180F (AC On)
All my temps were measured using the DIC.
sebian is offline
post #13 of 14 Old 02-01-2019, 08:51 AM
classics01's Avatar
Oil Temperature Question
Hi Guys,
It is cold out but I noticed that my oil temp won't go above 84C (183.2 F) It actually bounces between 84C and 83C (183.2 F and 181.40 F) Is this normal? It is not falling in between the yellow lines as it is supposed to.
classics01 is offline
post #14 of 14 Old 02-06-2019, 07:26 AM
gbvinla's Avatar
2SSRS L99 coolant 198 and oil temp about 210 while cruising. I never go WOT with oil temp below 200. Personal preference but I have 93K miles so far, and it works.
SW shorty's, Borla ATAK cat back, SLP Blackwing CAI, Diode Dynamics DRL's, Technostalgia LED sequential tail lights. beauty bar.
gbvinla is offline
