2013 trunk leak NO SUNROOF - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 2 Old 01-09-2018, 08:19 PM Thread Starter
Capital's Avatar
Question 2013 trunk leak NO SUNROOF
Had a little fender bender along the driver's side. Developed a leak in the trunk on the driver's side. The mechanic said the leak isn't due to the accident but because of "clogged drains". I know what he means. But I thought only cars with sunroofs had those drain hoses. I don't have a sunroof.
Is there a drain for non-sunroof camaros? If so, where? Thank you.
Capital is offline
post #2 of 2 Old 01-12-2018, 10:33 PM
There isn't a drain in the trunk that I'm aware of on the non-sunroof Camaros. Was this from a Chevy mechanic? If it was I would take it back and ask them to show you what drain they were referring to.
I do recall reading about a few isolated cases of the trunk seal not being seated properly causing some leakage issues years ago so you might want to check into that too. Here's a couple of threads that discusses similar issues and the second one is on a 2013 with no sunroof...
https://www.moderncamaro.com/forum/ge...ater-leak.html
http://www.camaro5.com/forums/showthread.php?t=510453
