water sucked into intake from car wash - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 14 Old 01-15-2010, 06:18 PM Thread Starter
brandonppr's Avatar
My wife took our durango that I just bought 2 months ago to the car wash. 99 5.2L I think. She said that when she went into the out car wash that the engine quit. She started it back and she said it ran very rough and was spraying/squirting water out from the engine area. She is not sure where it came from. She said it ran rough all the way home and by the time she got home it was running better. Now it runs but seems to have a miss. I looked it over and it has a bent fender on the pass side and a gap where a side spray of water could go in from the wash. That is the side that the intake is on. The intake is missing the piece that routes it into the fender. So it is just open and then goes to the filter. I think it could have sucked up the water into the intake.
What do you think would cause the miss?
brandonppr is offline
post #2 of 14 Old 01-15-2010, 06:34 PM
demonspeed's Avatar
Maybe pull the plugs to see how they look after the whole mishap?
www.fquick.com/demonspeed
Present: '02 SS #7146
demonspeed is offline
post #3 of 14 Old 01-15-2010, 08:18 PM
Well water and electronics don't mix well. I would leave the hood open and place a fan on top of the engine overnight to aide in drying things out. There may still be moisture in the coils/plugs wires, MAF connector etc etc.
post #4 of 14 Old 01-18-2010, 06:31 PM
Sgt Darkness's Avatar
Not to worry. My son put his '81 Olds Cutlass in my cousins pond. Over the engine and everything. Few oil changes, 4 trans changes and she fired up like a stage 4 rocket.................good luck.
10 Camaro LS/Magnaflow Exhaust/K&N CAI
08 Miata Grand Touring
06 Honda Civic EX
92 Honda Accord LX
73 Ford F-100, 302, 2 bbl
Sgt Darkness is offline
post #5 of 14 Old 01-19-2010, 07:46 AM Thread Starter
brandonppr's Avatar
It started and quit the next day, but now it seems to be running normal again. I am going to go ahead and do a tune up and change the oil anyway though.
post #6 of 14 Old 01-19-2010, 09:40 AM
RedJewel2SS's Avatar
check the IAC valve on the back of the throttle body for rusting, change it if needed or just clean it. its pretty easy to remove, just 2 hex screws on the back side of the throttle body. while having the air intake off it would be a good idea to clean the build up around the throttle plates as well with some carb cleaner!
i have a 98 dakota with the same engine as your durango, and for a while it would start and die like that. i checked the IAC valve and it was rusted stuck and would not move in or out. after replacing it and cleaning the throttle body she purred like a kitten and always started right up!
Gone but not Forgotten!
RedJewel2SS is offline
post #7 of 14 Old 01-25-2010, 01:20 AM
Moderator
slims00ls1z28's Avatar
Heh wow he got lucky then. I hit a deep puddle b4 in the Z and hydrolocked it.
slims00ls1z28 is offline
post #8 of 14 Old 01-25-2010, 01:35 AM
Luwinkle's Avatar
My father once drunkdrove his 1969 Firebird into a ditch full of water. The engine was basically underwater and was still running.
Luwinkle is offline
post #9 of 14 Old 01-25-2010, 01:48 PM
Cyrix2k's Avatar
this is by far the most likely outcome.
@OP, let it dry out. If it's not knocking, there's probably no internal damage.
1997 BMW 540i 6-speed
1996 BMW 318i Convertible (slow)
1985 BMW 325e 5-speed turbo (blown up, in the process of a motor swap)
1999 Oldsmobile Bravada (parted)
Cyrix2k is offline
post #10 of 14 Old 01-25-2010, 08:02 PM
HBZ28's Avatar
Too bad it's not a 305, you can't destroy one of those!!! I heard the 305tbi cars in hurricane Katrina still ran after being submerged for over a week! . Put a 305 in dat thing!!!
HBZ28 is offline
