Found a Gear Installer in Jacksonville, FL - ModernCamaro.com - 5th Generation Camaro Enthusiasts
Southeast Members KY, TN, WV, VA, NC, SC, AL, GA, FL
Also visit: 5TH GENS OF THE CAROLINAS
post #1 of 1 Old 06-15-2010, 07:47 PM Thread Starter
I had my 4.10 gears installed today by Josh at All Pro Automotive off of Levy Rd here in Jacksonville. He did a fantastic job, they don't make a bit of noise! I watched him do the installation, he did everything to exact specs and took his time setting everything up until it was perfect.
At first I was a bit skeptical looking at their facility as it is a bit dirty, but that's only because they are so **** busy. Soon after talking with Josh I knew he was the man for the job; he's done hundreds of differential setups for the local 4x4 guys.
Anyway, if you're looking to have gears installed, lookup All Pro Automotive and make sure Josh is the man that does the install. Great work!
FrostBite is offline
