V6 0-60 performance - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 19 Old 02-16-2011, 10:04 PM Thread Starter
mpiper's Avatar
V6 0-60 performance
How many out there have run a 0 - 60 test with a stock V6?
What were your results. What do you think affected the results?
I've run 7.1 to 7.3 consistently, just flooring it from a stop with the Auto in "D"
Running in "S" (Manual mode, but not touching the tap-shift) I get 7.0
Running "S", 1/4 tank, TC off and preloading TC to 1,000 RPM I can get 6.5
These are all on 91-93 Octane E10 (10% ethanol)
My car seems to be a dog 0-20, but pulls hard from that point on.
Anyone else?
mpiper is offline
post #2 of 19 Old 02-17-2011, 07:15 AM
Moderator
USA1Camaro's Avatar
I have seen one article and their 0-60 times were 6.1 seconds with a manual transmission. You seem to be in the ballpark with the 6.5 second run.
How were you timing? I think the car should be getting to 60 mph a little faster. Is the car spinning off the line with TC off?
EDIT: I found some guys claiming some very quick sub 6 second runs. TC was left ON. Sport mode.
Temperature. Barametric pressure, humidity and altitude all play into times. Also how many miles you have on the car?
USA1Camaro is offline
post #3 of 19 Old 02-17-2011, 09:40 AM
67 GTO's Avatar
I consistanly get low 5 second runs when in the cooler air at 350' above sea
This is using a Matrix Accelerometer. I've tested it against a 1/4 mile time slip and the meter showed 2 tenths better than I actually ran.
I can assume you could add maybe a tenth on a 60 mph test. I've noticed, as have others, that the meter completes the test at about 58 mph.
A good tool when comparing before and after modifications.
67 GTO is offline
post #4 of 19 Old 02-17-2011, 03:37 PM
JoJo Zzang's Avatar
I concur that - fastest I've got stock is 4.9 - perhaps the Colorado Springs air...
JoJo Zzang is offline
post #5 of 19 Old 02-17-2011, 03:50 PM
67 GTO's Avatar
One more, Brrrrrrrrr cold that day. This was with a GMPP axle back and a Airaid intake. I've since changed to a Injen CAI and JBA short headers.
67 GTO is offline
post #6 of 19 Old 02-17-2011, 08:39 PM
Moderator
USA1Camaro's Avatar
Those are some kick butt times !!
post #7 of 19 Old 02-17-2011, 10:14 PM Thread Starter
mpiper's Avatar
Wow! Those times look great!
I'm using the following:
OBD II connector to read car ECM. Bluetooth transmitter
My Android Phone ( Bluetooth reciever) running a program called "Torque"
The program reads the computer data straight from the computer. I assume it is reading the speedometer data and times from the second the wheels start rolling until the data hits 60 MPH.
The car has 2,100 miles on it. I drove soft for first 500, changed oil, drove soft with occasional runs up to 4,000 rpm. At 1,200 I started driving 50/50 soft/hard with rolling starts. Never did any hard starts until I hit 2,000. I'm 650 feet above sea level, the temperature on the 6.5 run was 66 degrees, and no idea the barometric pressure. How are those used in figuring the times? That's new to me. I've always done straight times.
How does the accelerometer read the vehicle speed?
Last edited by mpiper; 02-18-2011 at 07:23 AM. Reason: Forgot to answer mileage question.
mpiper is offline
post #8 of 19 Old 02-17-2011, 10:55 PM
54inches's Avatar
Add a second to anything a mile over sea level.
54inches is offline
post #9 of 19 Old 03-09-2011, 07:38 PM Thread Starter
mpiper's Avatar
Time for an update.
I've been less than satisfied with my 0-60 times, as recorded by the "Torque" app on my android phone. Several people suggested the app was not providing accurate numbers and that I should get a dash hawk. Some others suggested getting a K.A.T. Matrix Accelerometer. It has NO connection to the car, it just registers acceleration and uses that to time 0-60 and 1/4 mile times.
So, after getting over the sticker shock of the DashHawk, I decided to get the Matrix, since it's 1/10th the price. Just made three runs with it. I also had my "Torque" app running at the same time, just for comparison.
Now, since installing the Roto-Fab Intake, I've also never once gotten below 7.0 on Torque. So, I set the car's weight in the Matrix, suction cup it to the radio face and make my runs, listed below:
Matrix Torque
5.08 7.3
4.88 7.1
4.52 7.0
Uhm. . . WTH??? I expected a variance, but that's a bit incredible. While I love the numbers of the Matrix, I really don't believe them. And Torque gave me a calculated 251 RWHP and 220 Lbs/ft torque. So those numbers make sense.
So, what should I believe. Hm, the average? That comes to . . .5.98 And the funny thing is that's the number I wanted to see! But that was VERY Fuzzy Math. Time to read the manual on the Matrix in detail and see if there's more to it than just entering car's weight.
Thoughts?
mpiper is offline
post #10 of 19 Old 03-10-2011, 02:04 PM
54inches's Avatar
I would believe times at a race track and the dyno. Everything else is subject to LARGE amounts of error.
54inches is offline
