burnt smell from Exhaust - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 28 Old 03-31-2011, 11:40 AM Thread Starter
markgws6's Avatar
another noob question... my car now has over 200 miles on it. Performance is great and I'm pretty easy on it, usually never go over 4000RPMs. I have been smelling a burnt, almost like burnt plastic smell, coming from my exhaust or rear of the car after driven ever since the first test drive. Is this normal? One dealer guy told me it was the new cats burning in and another person told me it was agents the factory uses burning on the engine and that it will go away.
I've never had a new car do this before. Also the H20 temps always hover around 210-215. Isn't that a little high? Weather here is very nice only 70s and maybe low 80s now. I checked the coolant and it was a little low so I added some to the overflow bottle. Still have the smell and temp. I know little about these cars still, so any suggestions from the more experienced would be great!
markgws6 is offline
post #2 of 28 Old 03-31-2011, 11:49 AM
Thats normal the smell will go away shortly. Not sure about the other.
post #3 of 28 Old 03-31-2011, 11:57 AM
Absolutely normal. I had the same smell the first time I flipped on the AC and it totally freaked me out. So I'm more inclined to believe the engine coating explanation...but what do I know. But the smell was long gone before the 400 mile mark so no worries.
I made my dealer drive Envy until she didn't stink anymore. I just couldn't stand the smell. He was happy to oblige though.
post #4 of 28 Old 03-31-2011, 12:07 PM
What coolant did you add? I've read that the coolant that GM uses is not compatible with other brands. I'm just mentioning something I remember reading and I'm sure the guys have more information on the subject...so don't quote me. As far as the temp goes...I've never paid attention to the exact temp that mine runs at but I will and I'll get back to you with that. The water temp has always appeared to be in a safe range to me.
post #5 of 28 Old 03-31-2011, 12:24 PM Thread Starter
markgws6's Avatar
Thanks guys, I feel better now knowing some of you had the same thing happen and that it will go away. The coolant I added is Dex-cool compatible 50/50 just as the manual states. I still wonder what is burning to cause the stink. I think it's something either inside the exhaust or possible on the outside rubbing on the hot pipes. I noticed the muffler had a sticker left on it and I peeled most of it off but still had the smell.
markgws6 is offline
post #6 of 28 Old 03-31-2011, 12:28 PM
I never got the smell at all until I flipped on the fan so I don't think it's the exhaust. It appeared to come from the engine compartment to me.
post #7 of 28 Old 03-31-2011, 12:52 PM
Are you sure you didn't catch a plastic bag along the road somewhere? They melt right onto your exhaust, or other hot parts under the car and stink for a long time, even if you get most of it off.
kjd15 is offline
post #8 of 28 Old 03-31-2011, 02:51 PM
RedJewel2SS's Avatar
it is the oils in the exhaust from when they bent the tubing. perfectly normal.
there are also some paper tags on the exhaust that will eventually burn off as well.
Gone but not Forgotten!
RedJewel2SS is offline
post #9 of 28 Old 03-31-2011, 03:15 PM
What he said........
Once the Oils in the exhaust burn off you wont see smoke come out of the tail pipe and the smell will disappear.
Jekyll-N-Hyde is offline
post #10 of 28 Old 03-31-2011, 06:26 PM
The smell will go away. My dealer warned me about it before I signed the papers.
