My toy is broken - ModernCamaro.com - 5th Generation Camaro Enthusiasts
Old 04-17-2011, 10:39 PM Thread Starter
Question My toy is broken
2011 2LT 920 mi.
After quick acceleration to merge into traffic I felt a little rough idle.than I noticed a few days later a slight engine knock on startup which went away after a few seconds. I drove it a little w/o any other issues.Then during a 20 mile trip a rough misfire with a little rattling noise (no code) 5 min later check engine light with a misfire (and loud rattle ) code 2 min later dead on the side if the road!.The car was taken to the dealer and I am waiting to hear what happened. Any ideas out there?
Lazzzr is offline
Old 04-18-2011, 07:52 AM
Sorry to hear that, Hope it's not too bad!!! By the way, Welcome to the from Central Texas!!!
Old 04-18-2011, 08:15 AM
It might not be to bad I hope, it sounds bad but I hope for the best for you
Old 04-18-2011, 08:18 AM
The LLT's are having issues with the timing chains/tensioners.
EDIT: Also an issue with the camshaft end clearances under this TSB:
#08-06-01-011H: Malfunction Indicator Lamp On-Check Engine Light, DTCs P0011, P0014, P0021, P0024, P0341, P0346, P0366 or P0391 Set (Check Camshaft End Play and Perform Action as Outlined) - (Jan 8, 2010)
Subject: Malfunction Indicator Lamp On -- Check Engine Light, DTCs P0011, P0014, P0021, P0024, P0341, P0346, P0366, or P0391 Set (Check Camshaft End Play and Perform Action as Outlined)
Models: 2007-2009 Buick LaCrosse, Allure (Canada Only)
2010 Buick LaCrosse
2007-2010 Buick Enclave
2007-2009 Cadillac CTS, SRX, STS
2010 Cadillac CTS, CTS Wagon
2008-2010 Chevrolet Equinox, Malibu
2010 Chevrolet Camaro
2007-2010 GMC Acadia
2007-2009 Pontiac G6
2008-2009 Pontiac G8, Torrent
2007-2010 Saturn AURA, OUTLOOK
2008-2010 Saturn VUE
with 2.8L or 3.6L High Feature V6 Engine (VINs D, T, V, 7 -- RPOs LP1, LLT, LY7)
Attention: This bulletin also applies to any of the above models that may also be export vehicles.
This bulletin is being revised to add the 2010 Camaro and update the Camshaft Position Actuator to Front Camshaft Cap Measurement procedure to include end play check for both actuator designs. Please discard Corporate Bulletin Number 08-06-01-011G (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment that the check engine light is on.
Upon investigation, the technician may find one or more of the following DTCs stored:
• P0011
• P0014
• P0021
• P0024
• P0341
• P0346
• P0366
• P0391
Correction
Step
Action
Yes
No
1
Is vehicle an Acadia, Enclave or Outlook with P0011, P0014, P0021 or P0024?
Go to Step 2
Go to Step 3
2
Reprogram the ECM. Refer to Service Bulletin 08-06-04-011 for further information.
Do P0011, P0014, P0021 or P0024 still set?
Go to Step 3
Return vehicle to customer
3
Important: The set DTC will determine which camshafts (bank 1 or bank 2) should be checked.
Remove the camshaft cover and check camshaft end play on both camshafts in the suspect head using one of the methods listed below.
Is camshaft end play equal to or over 0.40 mm (0.016 in)?
Go to Step 5
Go to Step 4
4
Continue diagnosis using SI and call GM Technical Assistance, if necessary.
5
Check the gap between BOTH camshaft position actuators and the front camshaft cap using the Camshaft Position Actuator to Front Camshaft Cap Measurement Procedure listed below.
Does the 2.0 mm or 2.5 mm hex (allen) wrench fit between the position actuator and cap?
Go to Step 7
Go to Step 6
6
Install the camshaft thrust washers using the Camshaft Thrust Washer Installation Procedure listed below.
7
Replace the cylinder head and install thrust washers using the Camshaft Thrust Washer Installation Procedure listed below.
Old 04-18-2011, 12:56 PM
weland's Avatar
Anyone have a TSB for that? I have a SS, but I'm sure those with LT's would like to know.
Do not taunt Happy Fun Car.
weland is offline
Old 04-19-2011, 10:16 PM Thread Starter
The problem is in the engine so the dealer must do a tear down and inspection. I should have more news wed or thurs. I'll keep reporting.
And thanks for the "welcoming", great to have a camaro and to be here.
Lazzzr is offline
Old 04-19-2011, 10:22 PM
TX_SS's Avatar
oh yeah, just noticed your post count
Welcome Aboard
I'm hoping everything goes well for ya on the inspection and repair. You'll be on the road again in no time, but it's a little frustrating to not drive the Camaro
TX_SS is offline
Old 04-19-2011, 10:34 PM
markgws6's Avatar
Was there any smoke? Did they run the codes yet to check to see what was reported? Hopefully they do not have to pull your motor or anything. Oh and welcome!
markgws6 is offline
Old 04-20-2011, 07:54 PM Thread Starter
The bad news is after a teardown metal was found all over indicating a bearing failure or something just as bad. New block or new engine will find out more tomm. I'll post again. Thanks for the well wishes.
Lazzzr is offline
Old 04-20-2011, 08:06 PM
Welcome.
Sorry to hear the sad news. At least it happened under warranty.
