Fog Lights!!!!! - Page 4 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #31 of 44 Old 07-16-2012, 10:37 PM
my dealer referred me to an external custom shop for my fog lights.. i was like why wont you guys do them.. he said they wont do them its against their policy.. so im like WTF ill just do them myself then.. they wont even order me parts.. he said they have to be installed by a shop that has a contract with GM to keep my warranty.. im like ok whatever.. your going to void my warranty because i slapped a couple fog lights on my car..
Havock is offline
post #32 of 44 Old 07-17-2012, 05:11 AM
They would have to prove that what ever you did caused the failure, (what ever the failure was) to void your warranty. There just lazy or dont want to mess with it. Do do it right (if you wanted factory) you would need a harness and a new headlight switch. Not worth the hassell. Contact AAC lighting I beleive they have a kit and just install an aftermarket switch.
post #33 of 44 Old 07-17-2012, 06:05 AM
sycraft's Avatar
Ok, here is the deal, You can add
OEM foglights to the 2010-2011 Camaro , you need the front harness, lights, bezels and switch, all plug and play, then you go to dealer and ask them to get a new VCI for the BCM, they will call and GM will charge for that, then your oem fogs will work like they were designed, all factory.
For 2012 You must do the same thing, but the programming for the 2012 has not been released yet, I have the Test vehicle for the programming, and it will work, so GM will be releasing the update for GM dealers to use soon. the 2012 is different for some reason, they had to go through the PCM to get mine programmed. Everything works like factory, right down to the dash indicators.
The front harness and switch are pretty cheap, the harness replaces the non- fog harness in the front bumper.
And GM will now cover them for the remainder of the factory warranty, it is BS that your dealer will not get your parts or install them..
sycraft is offline
post #34 of 44 Old 07-17-2012, 04:46 PM
So how much is the harness and switch, I have an RS and want the function of the NoN RS fog lights..
post #35 of 44 Old 07-17-2012, 08:46 PM
sycraft's Avatar
N ot sure if that would work, maybe. the switch is around 35 and the harness around 50
sycraft is offline
post #36 of 44 Old 07-18-2012, 09:47 AM
See You On Course
CUONCRS's Avatar
Sounds like a visit to a different dealer to me.
2010 Stock IBM 2SS/RS
CUONCRS is offline
post #37 of 44 Old 07-20-2012, 01:37 PM
mikeru's Avatar
You're getting off cheap. I paid 29K for my fog lights.
2010 Camaro 1SS/RS CGM A6
mikeru is offline
post #38 of 44 Old 07-22-2012, 11:06 PM
those are some expensive fog lights.. lol
Havock is offline
post #39 of 44 Old 07-23-2012, 11:55 AM
Well I hope they threw the car in for free with those fog lights...!!
post #40 of 44 Old 07-26-2012, 08:29 AM
See You On Course
CUONCRS's Avatar
Yeah, and that was just for one fog light! They were "buy one get one free" at the time, too, weren't they? I saw that advertised special.
CUONCRS is offline
