Engine code - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 05-01-2011, 12:33 AM Thread Starter
Ariv46's Avatar
Angry Engine code
I installed a K&N air charger short ram. It keeps throwing me fuel system lean codes. Has anyone heard of this?
Ariv46 is offline
post #2 of 8 Old 05-01-2011, 12:47 AM
Sorry to hear you're having a problem. The CEL issue was why I didn't buy a K&N for my V6.
post #3 of 8 Old 05-01-2011, 03:47 AM
steeleshark2's Avatar
Unplug the battery for 10 minutes. Also, verify all connections are good and tight with no air leaks. See if that works for ya!
steeleshark2 is offline
post #4 of 8 Old 05-03-2011, 10:01 PM
Mandy's Avatar
Maybe you put in the maf sensor wrong? Or damaged it while installing? I just installed mine and had no problems whatsoever. The instructions that come with the show everything in detail so if you followed them you shouldn't have had an issue...
Mandy is offline
post #5 of 8 Old 05-04-2011, 08:59 AM
CamaroFTW's Avatar
i haven't had a single issue since installing my K&N aircharger....just unplug the battery it and make sure the M.A.F. is nice and snug on all 6 points....i know mine was a total P.I.T.A. during install (the MAF clip wasn't properly fitting into the bracket to mount to the tube), but it's worth it for no CEL's
2011 Chevy Camaro 2LT/RS Convertible Auto, CGM
2010 Chevy Camaro 1LT 3.6L Manual [Production #115] Black with cyber grey stripes (http://www.cardomain.com/ride/3370622) Traded 12/10/11
August 2011 MotM
-"Team LLT" representative
South Jersey Camaro Club member
CamaroFTW is offline
post #6 of 8 Old 05-04-2011, 10:30 AM
Mandy's Avatar
Yeah there's a certain way to get it to seat in that bracket... it wouldn't go for me either for like 10 min then I pulled it out and started on one side and it snapped right in. The pictures also show which direction the maf sensor is supposed to go into the tube... which could cause a problem if you put it in backwards. Hopefully he got it figured out
Mandy is offline
post #7 of 8 Old 05-11-2011, 10:42 PM
i had the same thing happen to. I even went to my dealer to have them chek things out they said [email protected] cai are junk. so i had to put the factory stuff back on the runs great. now
MileHigh is offline
post #8 of 8 Old 05-12-2011, 06:54 AM
Mandy's Avatar
Idk how they could be junk if you are putting the stock maf sensor in it?? Its just a tube and filter. Im still yet to have a code with mine.
Mandy is offline
