MAF sensor upgrade - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 6 Old 07-25-2011, 07:19 PM Thread Starter
JoJo Zzang's Avatar
MAF sensor upgrade
Anyone use or know of how these work? Planning on purchasing the underpulley upgrade as well as aAF sensor upgrade.
2010 Limited Edition Synergy Green Camaro
JoJo Zzang is offline
post #2 of 6 Old 07-25-2011, 07:31 PM
JET Performance makes a great Mass Air Sensor which increases air flow by around 45%.
I think that is what you are looking for on your Camaro
Jet Powr-Flow Mass Air Sensor (2010 & 2011 Camaro V6)
Also SLP makes a great underdrive pulley for the 2010 - 2012 Camaro V6.
2010 - 2012 Camaro V6 SLP Underdrive Pulley
MoranoRacing is offline
post #3 of 6 Old 07-25-2011, 07:42 PM Thread Starter
JoJo Zzang's Avatar
Yea, but are the MAF sensor upgrades proven to work? Do they throw any codes?
post #4 of 6 Old 07-26-2011, 02:42 AM
How does replacing the OEM Maf with this improve airflow ? The Maf reads how much air is flowing through the intake and along with the O2 sensor , sends a message to the ECU to add or reduce the amount of gas. The throttle body is the restriction,increase the I/D and you will have more airflow.
FastFreddy is offline
post #5 of 6 Old 07-26-2011, 08:12 AM
POWERFREAK's Avatar
yeah, not worth the $$, the stock MAF works fine.
the under-drive pulley should be worth a few HP though.
POWERFREAK is offline
post #6 of 6 Old 07-26-2011, 10:34 AM
I would check the MAF in your car to verify it is a "strong" unit (I think this applied to the V6). Check for a letter and 2 numbers for it to be a strong unit. Replace with a strong one if not (APEX sells verified strong ones). I have read that the Jet units are relabeled stock units, nothing else. This was stated by a reliable tuner.
