K&N Intake 63 or 69 Series - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 11 Old 09-11-2011, 04:07 PM Thread Starter
ZRak's Avatar
I've been searching around, and I wanted to know the benefits and downfalls between the K&N 63 Aircharger Highflow Intake Kit and and K&N 69 Typhoon Intake Kit.
Which one is an overall better intake between the two?
ZRak is offline
post #2 of 11 Old 09-12-2011, 09:40 AM
cruznls's Avatar
Wink
Possible CEL with the 63....
We have the Typhoon on our LS... No CEL...
Looks good & has good performance ,
maybe not the best on the market, but for the price {$216.00}
it was the best for us...
It does have a whistling sound on acceleration..
K&N told us whistlin's is workin'....
cruznls is offline
post #3 of 11 Old 09-12-2011, 10:00 AM
redhotcandy's Avatar
re: K&N 63 or 69
I can tell you from experience this: I initially installed the 63 series and within 3 or 4 days, my CEL light came on and didn't go off until I took it to the dealer for reset. They checked and said the cai was causing my car to "run lean." After resetting the code, it came on again within two days and stayed on. Then, three weeks later, my Stabilitrac and Traction control lights came on, so I took it back to the dealer. Upon checking it again, they said the O2 sensors were going crazy and it was still running lean and suggested that I take the 63 series off and don't put any cai on the car. They said the computers weren't recognizing the aftermarket part and therefore, throwing codes because of it. Prior to going to the dealer for the 2nd time, I spoke with a rep from K&N about the codes and he suggested that I try the Typhoon (69 series.) So, I ordered it and will send back the 63. I installed the Typhoon about six days ago and NO CODES! I'm really excited about this, I didn't like my dash lit up like a Christmas tree! I'm getting the same sound as the 63 (a good sound) and I think my gas mileage should be better since the 63 was causing me to use more fuel by running lean. I have read on other posts that some have had no codes with the 63, but it seems that more than not are getting codes with it. Good luck!
redhotcandy is offline
post #4 of 11 Old 09-12-2011, 11:27 AM
JPB
Hey all, I am a newbie. I have a 2010 ss2. I bought a K&N 63 and I installed it without any issue. Keep in mind I am in no way a mechanic, which may be why I a concerned. I have been reading about a lot of issues with these systems. The oil from the filter getting on the air flow sensor and causing problems. I understand that K&N says this is impossible. I also read somewhere about water getting to the engine through the filter and causing problems. I also had a mechanic, no one that I actually know, tell me to remove the K&N immediately and put the factory one back on.
Has anyone had any of these problems and should I be really concerned?
Thanks
JPB is offline
post #5 of 11 Old 09-12-2011, 11:36 AM Thread Starter
ZRak's Avatar
That's good I am glad everything turned out great So no lights or anything came on at all after installation?
Thanks for the great info! I am really considering the typhoon as my friend had this exhaust on his GTI and he loved it!
Thanks
Hmm well i know about the water factor there is a guard you can buy for it to help protect the intake. Regarding the other problems I am not sure only because I haven't myself experienced either of the two intakes.
ZRak is offline
post #6 of 11 Old 09-12-2011, 11:53 AM
JPB
Yes I have seen the guard or drycharger and I think i will order one, assuming I decide to keep it on.
JPB is offline
post #7 of 11 Old 10-10-2011, 04:38 PM
K&N Typhoon update...
It's been a month since I replaced the K&N 63 with the Typhoon and STILL NO CODES! Looks like a winner!
post #8 of 11 Old 10-10-2011, 04:43 PM
K&Ns on several vehicles for many years, no problems. No oil contamination, no water ingress, even on my Silverado.
post #9 of 11 Old 10-10-2011, 05:56 PM
CamaroFTW's Avatar
Have a 63 on my 1LT...bout a year now..no cel
2011 Chevy Camaro 2LT/RS Convertible Auto, CGM
2010 Chevy Camaro 1LT 3.6L Manual [Production #115] Black with cyber grey stripes (http://www.cardomain.com/ride/3370622) Traded 12/10/11
August 2011 MotM
-"Team LLT" representative
South Jersey Camaro Club member
CamaroFTW is offline
post #10 of 11 Old 10-11-2011, 12:07 AM
Spok's Avatar
I installed a K&N series 69 CAI on my 2010 2SS when I first bought it new in February of this year. So far there have been no problems though I don't know that there's been any change in power or fuel consumption as compared to the stock filter/intake box.
Spok is offline
