Lag in acceleration when you get r dun !. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 14 Old 07-31-2013, 05:45 PM Thread Starter
Mjclemm's Avatar
Hello guys, any of the Camaros (v6) lag when you punch it ? Mine lags quite a bit. Can we get the PCM reprogrammed to avoid this lag ? Or can you buy a programmer to do it ? Anyone with any experience with the reprogramming ? Thanks...mjclemm...
Mjclemm is offline
post #2 of 14 Old 07-31-2013, 06:14 PM
SS Talia's Avatar
I owned a 2LT for a bit and I think it's normal to have a slight lag. Depending on how bad it is, might wanna get it checked out.. maybe even find a dealership that will let you test another out to compare.
One way to go for better throttle response would be a ported throttle body. I've heard good things about VMAX's Ported TB.
Just in case you didn't know, a tune is a warranty voider if that matters to you. Some companies claim "stealth" tunes, but from what I've read, they can all be detected.
SS Talia is offline
post #3 of 14 Old 07-31-2013, 06:18 PM
ChibiBlackSheep's Avatar
I think a lot of it has to do with the power band. The thing needs to be high in the revs before it gets all of the tq
2013 IOM Camaro 1LS - Daily Driver
1968 Camaro SS - Weekend Warrior
2000 Monte Carlo SS - CSC Powered Project Car
ChibiBlackSheep is offline
post #4 of 14 Old 08-01-2013, 06:35 AM
Do you have a auto or v6? I have the VMAX TB and it gets rid of the lag your taking about.
post #5 of 14 Old 08-01-2013, 07:33 AM
me.. vert does it too, I thought it was me.. but thats when I'm in D.. computer manually shifts.. tho,
M.. I thinks is meant to paddle shift, witch will give you manual control & no lag..
Guapo.. I thinks hes got a A6-V6
post #6 of 14 Old 08-01-2013, 12:21 PM Thread Starter
Mjclemm's Avatar
Hello guys, thanks for the replies.... I just have the lil V6 right now, plan to do MAJOR upgrades though...I don't want to void the warranty just yet...lol.. Does adding the throttle body void the warranty ? Is this a DIY ? Just looked under the hood and just went into shock.. Thought I was new to cars in general.. No trans dip stick ?..lol... No Batter?... I was like...um.. I can't find the dip stick, or battery... My wife laughed at me...lol.. (Read the manual and am now educated on the location of the battery and the reason there is no dip stick for the trans). I thank you all again...Michael...
Mjclemm is offline
post #7 of 14 Old 08-02-2013, 10:40 PM
Misty's Avatar
After I installed a VMAX ported TB I noticed a big improvement in response.
Misty is offline
post #8 of 14 Old 08-03-2013, 07:51 AM
Any pics Misty..
post #9 of 14 Old 08-03-2013, 01:34 PM
Yes its DYI about 10 to 15 min max. Contact Ivan at southwest speed in New Mexico hes the best...
post #10 of 14 Old 08-06-2013, 08:44 PM
S.Bretz's Avatar
The lag is normal with a drive by wire system.
The ECM sees the accel pedal as a "torque requested" based on a preset calibration. The ECM will calculate your "torque request" when you step on the pedal and then calculates the best gear to shift to when you request torque.
If you reqest an output that is not capable with the gear the car is currently in, it will shift to the appropiate gear AND apply throttle at the same time....this is where the delay comes from.
The ECM does thi based on programming for emissions. On an older system the throttle would go wide open fromt he cable and there would be a very short amount of time that the ECM would communitcate with the TCM and then the TCM would down shift. This resulted in more immediate engine reaction but resulted in fuel wasted while the tran was still in the higher gear.
Drive by wire does have advantages for saving fuel. You can program the car to have a more responsive throttle....you input 10% of the throttl pedal and you get 30% throttle plate movement...or you can input 30% throttle and only get 10% plate movement. Some cars are letting the driver choose now by adding an ECO mode and/or a performance mode to do this.
PS: GM got this torque request drive by wire setup from SAAB
S.Bretz is offline
