Oil Level On Dipstick After Changing... - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 08-18-2013, 10:16 AM Thread Starter
when I picked up my 2013 2LS, I checked the oil level...It showed slightly more than 1/2 qt low...
I added enuff to bring it to the full mark...
I changed oil and filter this weekend...exactly 6 qts...
the dipstick shows 1/2 qt low...
Xkvator is offline
post #2 of 8 Old 08-18-2013, 10:32 AM
Wow, thats weird, I just did mine, it looks fine.. I used 6qrts, keep an eye on it, check under the camaro once and awhile too, you might have a leek
post #3 of 8 Old 08-18-2013, 03:54 PM
Xkvator,
If you did it once that could have given you a false reading. When I check the oil in my Impala SS I have to check the oil at least three times cuz sometimes oil is left on the stick even though you gave it a wipe down I myself can figure it out when this condition happens. For you car/Camaro I'd check it three time consecutively to get a more accurate reading.
Recheck on a cold engine that's on level ground. If you get a low reading I'd fill it to the top and forget it. That 1/2 quart low couls account for the small oil film circulated inside your motor.
Mail Clerk
mailclerk is offline
post #4 of 8 Old 08-18-2013, 05:37 PM Thread Starter
I've checked it many more than 3 times now...level surfaces at different locations...still same...
funny thing...it happens the same on 2 of my daughters Equinox's(4 cyl)...although only 1/4 qt low...
and its reported on the Equinox Forum too...
I'm sure all the oil companies aren't cheating on the amount theyre putting in the bottles...or are they?...
one of these days, ill stop at the dealer and try some other dipsticks...
Xkvator is offline
post #5 of 8 Old 08-18-2013, 05:38 PM Thread Starter
No, no leaks...oil level never changed, either...
Xkvator is offline
post #6 of 8 Old 08-18-2013, 05:55 PM
83Hokie's Avatar
Cold versus hot? I got home from an oil change and checked mine and thought I was way low ... waited overnight and it looked right
83Hokie is offline
post #7 of 8 Old 08-19-2013, 10:28 AM
It's possible that in actuality the oil sump holds 6 1/2 quarts of oil instead of the printed 6 quarts in the manual. Still that 1/2 quart is in the safe zone so perhaps you have nothing to worry about unless it bugs you then go ahead and add 1/2 quart of oil.
If you do so just keep and eye on it once per month and re-check the oil again and if you low 1/2 quart after a couple months just add that left over 1/2 quart.
Mail Clerk
post #8 of 8 Old 08-19-2013, 04:37 PM
S.Bretz's Avatar
Alldata always states that the listed capacity is an approximation and that the level should be checked after filling.
You should start the engine and let it run for about 10secs too so that filter housing can be filled. Then check it (eng off of course).
S.Bretz is offline
