Modifications.... - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 3 Old 10-28-2013, 10:19 AM Thread Starter
xxSkullZxx
xxSkullZxx's Avatar
Modifications....
hey guys, I was wondering with all of the modifications that a lot of you seem to be doing with your Camaro's if the factory warranty has expired on your cars? The reason I ask is from what I have heard, a lot of the things you all are doing to your cars should be voiding your warranty's. I have heard things like Cold Air Intakes, certain exhaust modifications and some other things fall into that category.
xxSkullZxx is offline
post #2 of 3 Old 10-28-2013, 10:44 AM
I voided my warranty when installed the cam/headers/hi-flow cats/stall convertor set up back in Feb.
Order #: VBBDZ1
2017 Camaro ZL1
Ordered: 12/26/16
Blue10CamaroSS is offline
post #3 of 3 Old 10-28-2013, 11:57 AM
geonny04's Avatar
cold air intakes, exhaust, or anything that you buy aftermarket is fine(in most cases) and will not void your warranty. you are protected by the law below. forced induction, internal engine components or porting/polishing will void your warranty. obviously your 3/36 exhaust warranty goes out the window but your powertrain(obviously most important) will stay intact.
MAGNUSON MOSS WARRANTY ACT
US Code - Title 15, Chapter 50, Sections 2301-2312.
Here's a copy of it:
geonny04 is offline
