Mace LFX Manifold Spacers Install - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 4 Old 03-05-2014, 06:37 PM Thread Starter
Just got a package in the Mail from MACE ENGINEERING containing a 6mm and a 12 mm spacer. I will be installing the 12mm first and documenting the install. I will be driving around and doing a little logging in hp tuners as well.
BlackoutLFX is offline
post #2 of 4 Old 03-05-2014, 07:17 PM
S.Bretz's Avatar
Nice looking piece.
Have you thought about using copper headgasket spray? It will produce a nice think sealing layer that won't ooze all over the place.
S.Bretz is offline
post #3 of 4 Old 03-07-2014, 09:31 AM
JacFab.com
RacnJsn95's Avatar
Originally Posted by S.Bretz View Post
Nice looking piece.
That's a good idea... But I think if either the spacer, or lower intake piece isn't dead flat there may be a slight chance that it may not seal? Then again it may work fine.
RacnJsn95 is offline
post #4 of 4 Old 03-08-2014, 06:42 AM
S.Bretz's Avatar
There should be some give in the spacer to compensate for any unevenness, but then again, I have not had my hands on one so I cannot comment on how malleable or rigid the piece is.
S.Bretz is offline
