rough idle - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 4 Old 04-07-2014, 11:07 AM Thread Starter
rough idle
Hello to all,
I was sitting in traffic this past Sunday and noticed my engine ran kind rough and for the first time the engine appeared to almost die but the computer didn't toos me any engine codes.
Has any of you had the same engine condition while sitting iin city traffic on you RS/V-6??? I always use Chevron mid grade gas.
Mail Clerk
mailclerk is offline
post #2 of 4 Old 04-07-2014, 12:42 PM
mphoob's Avatar
I don't have the V6 but I've noticed something similar, just not so much to think it was gonna die or anything.....just chalked itup to hvac and normal power surges??? but don't count on anything I say as valid or law, I am a very simple driver kind of guy too
At last--Dream HAS BECOME Reality....
mphoob is offline
post #3 of 4 Old 04-07-2014, 08:03 PM
S.Bretz's Avatar
Check the oil level....if the oil level gets low then the VVT system doesn't have enough oil to operate the cams and it will run like a sac of turds.
If the oil level is ok, it is either a coil dropping out or carbon build up on the intake valves.
Crap gas or fancy gas ...it doesn't matter on DI since the fuel is not there to flow over the intake valves and keep them clean.
How many miles do you have on it?
S.Bretz is offline
post #4 of 4 Old 04-07-2014, 09:37 PM Thread Starter
S. Bretz,
The oil level should be up. I just had it's first OCI done from the dealership at just slightly over 6K.
I hope it's not any of my coils. I've so far have not seen any engine codes tossed my way yet. Perhaps it's a bad tank of gas.
Mail Clerk
