2014 v-6 - Page 3 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #21 of 95 Old 07-24-2014, 12:08 PM Thread Starter
rustyz's Avatar
ya its nice not having to fight with them like other dealers
rustyz is offline
post #22 of 95 Old 07-25-2014, 09:15 AM
Its good that you got a great dealer.. hope they keep their word, the main thing is that your happy
Tho, if it was me, I'd get the dealer to trade me to another one, just to be on the safe side.. things always happen & at the end.. its best to cover your toosh than hoping someone your not 100% sure will IMO
post #23 of 95 Old 07-25-2014, 12:10 PM Thread Starter
rustyz's Avatar
had to take her back today! its a cracked head and gm knows all about it lotta v-6,s have bad heads. its a defect where the plugs go in.
rustyz is offline
post #24 of 95 Old 07-25-2014, 12:48 PM
Will have to keep an eye on mine...
post #25 of 95 Old 07-25-2014, 01:39 PM Thread Starter
rustyz's Avatar
ya bama you get an engine light and it comes up misfires you,ll know. hope you never have to have this done.
rustyz is offline
post #26 of 95 Old 07-25-2014, 06:04 PM
S.Bretz's Avatar
Its rare but it happens. It has to do with the way they sleeve the blocks.
The old way they would cast the block and bore it out for an interference press-fit steel sleeve. This is ok but as the block heats up the aluminum expands at about twice the rate of the steel so the sleeves would get a little loose.
The way they make these newer HO v6's is that the heat the sleeves up and pour the cast around the sleeve that way when it up to temp the sleeve is still pretty tight to the alum casting...but when it cools down the alum can crack since the alum shrinks twice as fast as the steel sleeve.
...If happens every once and a while, but not very often, but this is a prime example of why they put warranties on new cars.
S.Bretz is offline
post #27 of 95 Old 07-25-2014, 07:33 PM Thread Starter
rustyz's Avatar
yes and thank god they do. this is a costly job
rustyz is offline
post #28 of 95 Old 07-26-2014, 12:41 PM
Wow.. sorry bro.. to hear you had to take her back
post #29 of 95 Old 07-30-2014, 11:20 PM
S.Bretz's Avatar
Glad to hear the CAC is working out.
S.Bretz is offline
post #30 of 95 Old 07-31-2014, 07:30 AM Thread Starter
rustyz's Avatar
not worked out yet but there talking! I,m afraid that's all it will be. thay asked what would make me happy I said a new car !
rustyz is offline
